it shows 300Mhz and it should be 680Mhz does it?
what’s the serial number of this device? i will check what model it is, maybe it just shows 750G. does it actually work at gigabit?
SN: 1FC201AD20CF/943
and yes it runs gigabit
I get it with ROS 3.31 so it should be 750G
but i didn’t check the core freq before upgrade to 4.5 but it should not matter:)
Try this:
[admin@RB750G] > system routerboard settings set cpu-frequency=[TAB][TAB]
100MHz 150MHz 200MHz 300MHz 400MHz 600MHz 680MHz 800MHz
such a simple thing
thx Normis
btw why it has core set to 300Mhz?? i didn’t do that so someone from Mikrotik or reselers have to do that:)
make sure you come to the MUM in march ![]()
i will
maby we will talk about it there:D
