I have two MT v2.9.11 boxes. One is an AP with an omni antenna and the other is acting as a station with a directional grid. They are about .2 miles apart and the signal level is ~-55. The station has a CM9 card, the AP has an Atheros 5354. 802.11a with no nstream
Everyone couple hours the station will disconnect from the AP and won’t rejoin until 20-60 minutes later. Dis and re enabling the interface on either end does not fix the problem.
When this occurs I see the following in the logs:
At the AP
wireless,info wlan2: disconnected 00:0B:6B:37:A2:A3, inactivity
At the station
00:10:18 wireless,info wlan1: lost connection to 00:02:6F:21:EC:80, got disassoc: no activity (4)
00:10:20 wireless,info wlan1: connected to 00:02:6F:21:EC:80 on 5765, SSID JackalNet2
00:33:18 wireless,info wlan1: lost connection to 00:02:6F:21:EC:80, no beacons
00:33:23 wireless,info wlan1: failed to connect to 00:02:6F:21:EC:80, join timeout
00:33:36 wireless,info wlan1: failed to connect to 00:02:6F:21:EC:80, join timeout
00:33:51 wireless,info wlan1: failed to connect to 00:02:6F:21:EC:80, join timeout
00:34:15 wireless,info wlan1: failed to connect to 00:02:6F:21:EC:80, join timeout
00:34:27 wireless,info wlan1: failed to connect to 00:02:6F:21:EC:80, join timeout
00:34:51 wireless,info wlan1: failed to connect to 00:02:6F:21:EC:80, join timeout
00:35:03 wireless,info wlan1: failed to connect to 00:02:6F:21:EC:80, join timeout
00:35:33 wireless,info wlan1: failed to connect to 00:02:6F:21:EC:80, join timeout
Here is the AP config
set wlan2 name=“wlan2” mtu=1500 mac-address=00:02:6F:21:EC:80 arp=enabled disable-running-check=no
radio-name=“00026F21EC80” mode=ap-bridge ssid=“JackalNet2” area=“” frequency-mode=manual-txpower
country=no_country_set antenna-gain=0 frequency=5765 band=5ghz scan-list=default
rate-set=configured supported-rates-b=1Mbps,2Mbps,5.5Mbps,11Mbps
supported-rates-a/g=6Mbps,9Mbps,12Mbps,18Mbps,24Mbps,36Mbps,48Mbps basic-rates-b=1Mbps
basic-rates-a/g=6Mbps max-station-count=2007 ack-timeout=dynamic tx-power-mode=default
noise-floor-threshold=default periodic-calibration=disabled burst-time=disabled dfs-mode=none
antenna-mode=ant-a wds-mode=disabled wds-default-bridge=none wds-ignore-ssid=no
update-stats-interval=disabled default-authentication=yes default-forwarding=yes
default-ap-tx-limit=0 default-client-tx-limit=0 hide-ssid=no security-profile=default
disconnect-timeout=10s on-fail-retry-time=100ms preamble-mode=both compression=no
allow-sharedkey=no comment=“” disabled=no
And the station config
set wlan1 name=“wlan1” mtu=1500 mac-address=00:0B:6B:37:A2:A3 arp=enabled
disable-running-check=no radio-name=“000B6B37A2A3” mode=station ssid=“JackalNet2” area=“”
frequency-mode=manual-txpower country=no_country_set antenna-gain=0 frequency=5765 band=5ghz
scan-list=default rate-set=default supported-rates-b=1Mbps
disconnect-timeout=3s on-fail-retry-time=100ms preamble-mode=both compression=no
