strange disconnects on 2.9
Hi all.
So, I have next problem :wink:
On MT 2.9: rc2, rc4 (not yet tested on rc5), prism 2,5 interface (clients on windows) I have strange issue.
Suddently every clients are disconnected for about one second, after that they connected again.
This happen sometimes one times on day, sometimes 1 times on hour, sometimes more.
Tested on 4 different place with different antennas.
In this time I see higher ping times (many duplicates).
Anyone had this problem?
MT Team: this is known issue?
PS. Why in logs there are no information about disconnects, only connects?
In my wireless network, to see disconnects and reconnects, I have to look at the log of the client device. On the Access Point, I only see the reconnects. I think this is because the AP doesn’t consider a client disconnected until it’s time-out value has been reached, and the client is reconnecting so fast that the AP hasn’t timed out yet in order to considered the connection lost. In other words, the AP is getting a reconnection before it even knew that the original connection was gone…
Hitek
on RC5 it is disame issue.
mikrotik help!!!
enable all logging. then send supout.rif file to support. make the file right after the disconnection happens
It’s done.
2 supout file from 2 routers are sent to: support@mikrotik.com
waiting for response :slight_smile:
Best regards
