Hi
I need a help please.
my mikrotik router showing strange Dst.Address 31.12.71.119:80 like this.
my Dst.Address is diffrent.
any help please
image file https://ibb.co/bvddd6n
thanks
KB
Hi
any help please
thanks
KB
You should probably share a few more details, like where exactly you see it, etc.
Hi Sob,
thanks for the reply. I attached the image file.
thanks
KB
And what is it you don’t like about it? It’s a connection from 192.168.?.? to this address. Tcp and port 80 is standard for unencrypted http.
my local ip is 192.168.88.10
my Dst.Address (server address) is starting with 70.152.- .-
but this Dst.Address 31.12.71.119:80 is not mine. strange address.
It looks like normal outgoing connection. Same as those dns queries to 8.8.8.8. Even if you’re connecting to 70.152.-.-, something else can be connecting to 31.12.71.119. You can easily find out that the address is http://yp.shoutcast.com/.
Hi Sob
thank you very much. I got it now.
thanks
KB
