Strange Wireless error
"not acceptable for security profile: does not provide privacy as profile requires "
The key are the same…
BUMP!!
Hello, any news?
I have fixed this problem on my setup. In the security profile tab I setup a new profile with wpa aes-ccm and put that on the wlan interface. I did this on both sides of the connection. I thought it was supposed to use that profile. Well I was wrong. In the connect list tab is where I needed to select the profile. Once I did this at both ends, they connected.
I tried. This not work in my setup.
Enabling tkip in security profile helped me with the same problem.
For google only … (thread was burried for ages, seems somebody managed to dig it … but it needs some sensible information in case somebody else comes by).
One has to know standard combinations: WPA goes with TKIP … and WPA2 goes with AES-CCM … No other combination is standard so basically don’t try to use them (unless you hate yourself). And unless you have ancient clients in your wireless network, just skip WPA+TKIP combo and go for WPA2+AES-CCM combo only.
