Hi all,
Recently I’ve faced quite strange problem with wireless speed on my R52n card. I use 433AH routerboard running 6.38.5 version of RouterOS. My hardware setup is as following:
[ISP provided Zyxel ADSL router LAN] → [Mikrotik LAN] → WiFi clients _The problem is as following:
- If I connect with my computer directly to ISP Zyxel over 5GHz WiFi, then I get ~70Mbps speed on speedtest.net
- If I connect to my Mikrotik 5GHz (R52n) then I get only ~40Mbps
What I have tried: - Disable WiFi on Zyxel, so it does not interfere with Mikrotik. Problem remains.
- Add Mikrotik to ISP router’s DMZ config, so I do not have double NAT config. Problem is the same.
- Connect my computer with LAN cable to Mikrotik. In that case I get ~70Mbps as supposed. LAN and WiFi use absolutely the same firewall rules. There are not differences.
- Tested speed between my computer and Mikrotik R52n card by using Mikrotik’s tool “BTest”. In that case I can reach up to ~110Mbps. Means there are no problems with WiFi card or computer drivers.
So it seems like double NAT is not a problem, WiFi signal is not interferring, firewall can process traffic at requited speed (after testing with LAN), WiFi can get speed up to ~100Mbps. But there is no way I get 70Mbps on speedtest.net while I’m connected to Mikrotik’s WiFi.
Any suggestions what to test or check? Maybe adjust some settings?
Just in case I’m pasting my WiFi config:_
0 R name="wlan1" mtu=1500 l2mtu=1600 mac-address=##:##:##:##:##:##
arp=enabled disable-running-check=no interface-type=Atheros AR92xx
radio-name="############" mode=ap-bridge ssid="xxxxxx" area=""
frequency-mode=manual-txpower country=no_country_set antenna-gain=0
frequency=5200 band=5ghz-a/n channel-width=20/40mhz-eC
scan-list=default wireless-protocol=802.11 rate-set=default
supported-rates-b=1Mbps,2Mbps,5.5Mbps,11Mbps
supported-rates-a/g=6Mbps,9Mbps,12Mbps,18Mbps,24Mbps,36Mbps,48Mbps,
54Mbps
basic-rates-b=1Mbps basic-rates-a/g=6Mbps max-station-count=2007
distance=indoors tx-power-mode=default noise-floor-threshold=default
nv2-noise-floor-offset=default vlan-mode=no-tag vlan-id=1
wds-mode=disabled wds-default-bridge=none wds-default-cost=100
wds-cost-range=50-150 wds-ignore-ssid=no update-stats-interval=disabled
bridge-mode=disabled default-authentication=no default-forwarding=no
default-ap-tx-limit=0 default-client-tx-limit=0 wmm-support=disabled
hide-ssid=no security-profile=secprof1 wps-mode=disabled
station-roaming=enabled disconnect-timeout=3s on-fail-retry-time=100ms
preamble-mode=both compression=no allow-sharedkey=no
station-bridge-clone-mac=00:00:00:00:00:00 ampdu-priorities=0
guard-interval=any
ht-supported-mcs=mcs-0,mcs-1,mcs-2,mcs-3,mcs-4,mcs-5,mcs-6,mcs-7,mcs-8,
mcs-9,mcs-10,mcs-11,mcs-12,mcs-13,mcs-14,mcs-15
ht-basic-mcs=mcs-0,mcs-1,mcs-2,mcs-3,mcs-4,mcs-5,mcs-6,mcs-7
tx-chains=0,1 rx-chains=0,1 amsdu-limit=8192 amsdu-threshold=8192
tdma-period-size=2 nv2-queue-count=2 nv2-qos=default nv2-cell-radius=30
nv2-security=disabled nv2-preshared-key="" hw-retries=7
frame-lifetime=0 adaptive-noise-immunity=none
hw-fragmentation-threshold=disabled hw-protection-mode=none
hw-protection-threshold=0 frequency-offset=0 rate-selection=advanced
multicast-helper=default multicast-buffering=enabled
keepalive-frames=enabled pci-info="00:13.0"
