Strange issue
Hello! I have 2 MK Router v5.5. Plus, there are some networks configured (in both), like:
1 - 192.168.0.0/24
2 - 192.168.1.0/24
Hosts can communicate between these networks, but, only 2 IP´s can´t. There are no rules in Firewall (in both Mikrotik equipments) that explains this. If i change the IP on host that has the problem, the communication works.
E. If i put a ip 192.168.0.238, there is no response to any host in 192.168.1.0/24 range. But, if i change to 192.168.0.239 for example, it works.
Any ideia where i have to look?
Thanks!
Are you seeing any devices via arp at the client when .238 is assigned?
What happens if you run a trace route from the client with .238 then .239?
Hello! I had to reset the system, after changing an option by mistake. After this, the issue disappeared.
