Strange log lines
Hi! I have Mikrotik RB951G-2HnD, v6.5. Yesterday I have configured logging to my syslog server and now I see some strange lines appearing every 10 minutes. Early on 6.2 and 5.24 i didn’t see them.
Oct 23 13:15:53 192.168.88.1 web-proxy1: disk setup finished successfully
Oct 23 13:15:53 192.168.88.1 user-manager1: disk setup finished successfully
Oct 23 13:25:53 192.168.88.1 web-proxy1: disk setup finished successfully
Oct 23 13:25:53 192.168.88.1 user-manager1: disk setup finished successfully
Oct 23 13:35:53 192.168.88.1 web-proxy1: disk setup finished successfully
Oct 23 13:35:53 192.168.88.1 user-manager1: disk setup finished successfully
What can it be?
Up!
Any ideas?
at least for the proxy I would assume the following:
The proxy creates a special directory structure for optimized file access speed. I would guess, the creation of this directory structure is meant by “Oct 23 13:15:53 192.168.88.1 web-proxy1: disk setup finished successfully”.
Ape
check proxy configuration also, do you have user-manager installed on the router?
Proxy has to be configured to this.
Also, maybe you are using hotspot (that enables proxy)
Thank you for responses!
Proxy is disabled. You want to say that this directory structure is rebuild every ten minutes? That makes no sense.
Hotspot server was created but stays unusable. Now I’ve disabled it.
Oct 24 16:36:25 192.168.88.1 web-proxy1: disk setup finished successfully
Oct 24 16:36:25 192.168.88.1 user-manager1: disk setup finished successfully
Oct 24 16:36:25 192.168.88.1 activating store for web-proxy1
Oct 24 16:36:25 192.168.88.1 web-proxy1: activation finished successfully
https://www.dropbox.com/s/n2jie90n61gd0rl/Скриншот%202013-10-24%2016.42.13.png
Main question is “Should I worry about this?”
Up!
Up! :smiley:
