Hy all,
this is my setup:
RB112 + SR2 + CM9 onboard, SR2 for hotspot and CM9 for backhaul.
When i ping flood the ip of RB112 via wireless (bridging beetween ethernet, SR2 and CM9), either to SR2 or CM9, the ping stays under 20ms, and every 3 second (terribly constant) it goes up (for a single ping) to 250-500ms.
This is very annoying, becouse the TCP throughput goes down every the same 3 seconds, from 5Mbps to 1,8-2,2Mbps (but no timeout or disconnection), and then it return to 5Mbps.
I tryed with a Linksys WRT54G/GL as client, and with Ubiquiti SRC PCMCIA client, but it’s the same thing. SR2 and CM9 are set on 2,4GHz band. SR2 is “only-b”, becouse, in “g mode” or “b/g” the ping goes terribly high (and, this is strange a lot for me, but it’s another problem…).
I tryed to disable one card, and then the other, but same thing happens. I tryed to disable radio calibration, polling, ssid broadcast, default authenticate, put fixed data-rates, ack-timeout from dynamic to static, compression…but no difference from the initial setup.
Is this a RouterOS bug (as i read on other post) or other?
Just tried to lower the power out of the SR2 to 20dBm: no result, same things.
When I made the ping flood, CPU stays beetween 2% and 6%.
Additional info: rb112 with a omni antenna 12dBi, client with a rootenna 14dBi, signal received by the client -72/-76dBm, signal received by RB112 -81/-86dBm, bitrate 11Mbps rock-solid, CCQ (on RB112 side) 98/100%.
Yes, we had “floods”, but many years ago!
Today, for the second day, the flood seems to be stable. The bug i illustrated here is no more visible. I’ll update this thread when this annoying “bug” will be again here, possibly with more details.
Is possible that this “bug” was produced by a small quantity of fog?
