I recently got myself an RB5009UPr+S+IN (which is fantastic) and a TP-Link Omada EAP650-Desktop access point that I want to run on PoE provided by the router.
Unfortunately, I’m seeing a weird issue where, shortly after booting the AP, its power LED starts flashing orange to indicate that it’s not receiving enough juice, and the transmit power on the 5GHz transmitter drops to practically nothing (like -90dB less than a metre away from the AP).
However, if I then pull the ethernet out of the AP and immediately put it back in again, or if I tell the RB5009 to power-cycle the ethernet port with a 0s delay, the AP reboots and subsequently operates at full transmit power without any further issues, (until the next time it gets powered down, and I have to do this stupid “boot-wait-reboot” procedure to get it running properly again). Interestingly, a soft reboot doesn’t seem to work; it needs to be a proper power-cycle.
The strange thing is, I only ever see the AP drawing around 120-160mA, (according to the PoE status in the RB5009), regardless of whether the AP is running normally or complaining about low power, and it never goes anywhere near the 440mA that the RB5009 is supposed to be able to output on a single port.
Furthermore, I’ve completely disabled PoE on all the RB5009’s ports except the one powering the AP, and the RB5009 is running on the 96W adaptor so there surely can’t be any power limits kicking in.
Also, the datasheet for the AP states that it will run fine on 802.3at but will disable the 5GHz transmitter on 802.3f, so the fact that it keeps the 5GHz transmitting at extremely low power while it’s complaining about the PoE seems odd to me.
Does anyone have any thoughts about what on earth could be going on? Defective AP? Defective router? Some kind of PoE compatibility problem between the two?
I don’t know how I could even go about diagnosing/troubleshooting such an issue…
Failing that, does anyone know of any other APs that might fit my requirements (desktop form factor, Wi-Fi 6, PoE-In, around £100)? The EAP650-Desktop was the only desktop AP I could find that supported both Wi-Fi 6 and PoE-In at a reasonable price-point. I don’t want wall/ceiling-mounted, and the next best desktop AP I came across was the UniFi U6 Mesh for nearly double the cost!
