Strange port forwarding problem
I am using RB49AH at home, and want udp 8021 to be forwarded to internal 172.16.1.111 address. Here is my configuration I use:
add action=accept chain=output comment=“” disabled=no src-address=
172.16.1.111
add action=dst-nat chain=dstnat comment=“” disabled=no dst-address=
78.128.xxx.xxx dst-port=8021 protocol=udp to-addresses=172.16.1.111
to-ports=8021
78.128.xxx.xxx dst-port=8021 protocol=tcp to-addresses=172.16.1.111
to-ports=8021
add action=dst-nat chain=dstnat comment=“” disabled=no dst-port=44645
in-interface=ether1 protocol=tcp to-addresses=172.16.1.118 to-ports=44645
add action=src-nat chain=srcnat comment=“” disabled=no src-address=
172.16.1.118 to-addresses=78.128.xxx.xxx
172.16.1.111 to-addresses=78.128.xxx.xxx
add action=masquerade chain=srcnat comment=“” disabled=no
add comment=“” disabled=no distance=1 dst-address=0.0.0.0/0 gateway=
78.128.xxx.xxx scope=30 target-scope=10
The port forwarding for 8021 is user for TV sharing, and winbox shows that there are packets going to .111 but the tv screen is black. When I switch the router with a wrt54gl linksys tv is going on. So, I have tried to use “in interface” ether1 instead “dst address” but the same. This “trick” was useful a month ago, when had the same problem. Then I added src-nat to the .111 address and put it before the masquerade. Still no TV. But when I deleted the masquerade, TV shines on. I created back the masquerade and everything was ok. That was yeasterday. Now I had to delete and create back the masquerade to turn the TV on. Another interesting moment is that the port 44645 forwarded to 118 is used for utorrent which stays with yellow or red icon showing that is not connectable. But when I test the port forwarding at the settings menu of utorrent, it say that the 44645 is opened. The router was with 3.23 firmware, but yesterday I upgraded to 3.25 hoping to resolve the problem.
Am I missing something from the firewall/NAT fundamentals or what? I’m confused.
http://wiki.mikrotik.com/wiki/Forwarding_a_port_to_an_internal_IP
Yes, that is what I’m doing. The strange is that it works with port 5900 to .118 with VNC, but the udp-packets to .111 not exactly.
