strange port forwarding
I’ve RB751U-2HnD v5.26 and on my small server are two java programs (SIP based).
  1. When I connect from inside of local network it runs flawlessly (new lines in log file).
  2. When I wanna connect from internet (or outside of local network) it seems one program is unreachable, but second runs flawlessly.
interface list is attached.
When I torch 2) it writes:
SRC | DEST
:<program 1 port> | :
:<program 1 port> | :<program 1 port>
Then progam on PC writes that program 1 on server seems to be down (no communication).
(in program 1 log is nothing new)
:<program 2 port> | :
Program 2 runs well.
(new lines in log)
My firewall nat options:
6 chain=dstnat action=dst-nat to-addresses= protocol=tcp
in-interface=ether1-gateway dst-port=<program 2 port>,<program 1 port>,
7 chain=dstnat action=dst-nat to-addresses= protocol=udp
From Internet I’m able to probe ports by Angry IP Scanner - shows <program 1 port> and <program 2 port> open.
When I connect PC to local network I’m unable (or I don’t know how) to torch this communication on any interface :frowning:
Thanks for help.
How are your firewall rules build?
Rudios … good point it could be the problem.
/ip firewall filter> print
 0   ;;; default configuration
     chain=input action=accept protocol=icmp
 1   ;;; default configuration
     chain=input action=accept connection-state=established
 2   ;;; default configuration
     chain=input action=accept connection-state=related
 3   ;;; default configuration
     chain=input action=drop in-interface=ether1-gateway
 4   ;;; default configuration
     chain=forward action=accept connection-state=established
 5   ;;; default configuration
     chain=forward action=accept connection-state=related
 6   ;;; default configuration
     chain=forward action=drop connection-state=invalid
If these are your only rules I am very surprised that the connection is even starting.
I do not know the applications you are using but keep in mind that UDP is a connectionless protocol so a firewall rule with connection-state=established will not work there!
On the other hand, you do not have a generic drop rule at the end which drops all remaining traffic, so it makes sense.
The rules you now actually have only block invalid traffic.
It’s strange - I see now. But I can’t figure out how to set firewall rules properly. I’ve made final forward firewall rule:
 8   chain=forward action=log log-prefix="drop::"
And log prints drop on both program 1 and 2 - but program 2 has higher size of packet (>1k).
Log also prints priority changes.
My Mangle rules for packet sizes are these:
3   ;;; low_size_in
     chain=postrouting action=set-priority new-priority=3 passthrough=yes
     packet-size=0-512
 4   ;;; low_size_out
     chain=prerouting action=set-priority new-priority=3 passthrough=yes
     packet-size=0-512
 5   ;;; hi_size_in
     chain=postrouting action=set-priority new-priority=7 passthrough=yes
     packet-size=513-65535
 6   ;;; hi_size_out
     chain=prerouting action=set-priority new-priority=7 passthrough=yes
I figure out now it shouldn’t work anyway. Could you please guide me or give some good resources?
I’ve tried add <program 1 port> to SIP service ports and program 1 seems to work :smiley: . I must do some more tests.
I’ve also recreated firewall rules.
