Hello everyone.
I just try make some script with will be cooperate with VRRP. Nothing special. I configured whole firewall on main router and i exported everything to backup router. Now.. I wont to make changes only on main router. So I wrote script:
if ([:len [/file find name=fw_address.rsc]]>0) do={/file remove fw_address.rsc}
if ([:len [/file find name=fw_filter.rsc]]>0) do={/file remove fw_filter.rsc}
if ([:len [/file find name=fw_layer7-protocol.rsc]]>0) do={/file remove fw_layer7-protocol.rsc}
if ([:len [/file find name=fw_mangle.rsc]]>0) do={/file remove fw_mangle.rsc}
if ([:len [/file find name=fw_nat.rsc]]>0) do={/file remove fw_nat.rsc}
if ([:len [/file find name=fw_service-port.rsc]]>0) do={/file remove fw_service-port.rsc}
/tool fetch mode=ftp address=... port=... src-path=fw_address.rsc user=red password=...
/tool fetch mode=ftp address=... port=... src-path=fw_filter.rsc user=red password=...
/tool fetch mode=ftp address=... port=... src-path=fw_layer7-protocol.rsc user=red password=...
/tool fetch mode=ftp address=... port=... src-path=fw_mangle.rsc user=red password=...
/tool fetch mode=ftp address=... port=... src-path=fw_nat.rsc user=red password=...
/tool fetch mode=ftp address=... port=... src-path=fw_service-port.rsc user=red password=...
foreach i in=[/ip firewall address-list find ] do={
/ip firewall address-list remove $i
import fw_address.rsc
foreach i in=[/ip firewall filter find ] do={
/ip firewall filter remove $i
import fw_filter.rsc
foreach i in=[/ip firewall layer7-protocol find ] do={
/ip firewall layer7-protocol remove $i
import fw_layer7-protocol.rsc
foreach i in=[/ip firewall mangle find ] do={
/ip firewall mangle remove $i
import fw_mangle.rsc
foreach i in=[/ip firewall nat find ] do={
/ip firewall nat remove $i
import fw_nat.rsc
foreach i in=[/ip firewall service-port find ] do={
/ip firewall service-port remove $i
import fw_service-port.rsc
Each part of firewall is exported separately because i was looking for problematic part. And i found it. This script sometime (50/50 changes) can’t erase all address-list entry. Script can erase only 20 of those. And exactly first 20 of imported. When i put this part:
nothing will be change.
So i can’t understand what is wrong.
Why sometimes whole 31 entry was erased, and why sometime script can erase only 20 and whole script is stopped.
I had the same problem when i exported and imported whole firewall config (/ip firewall export …)
Can somebody help me
sorry for my bad English.
