RouterBOOT booter 2.36
RouterBoard 411U
CPU frequency: 300 MHz
Memory size: 32 MB
Press any key within 2 seconds to enter setup..
writing settings to flash... OK
trying bootp protocol... OK
Got IP address: 10.0.0.2
resolved mac address 18:03:73:A9:6C:5E
*******transfer started ......................... transfer ok, time=7.74s
setting up elf image... OK
jumping to kernel code
Welcome to MikroTik Router Software remote installation
Press Ctrl-Alt-Delete to abort
mac-address: 00:0C:42:F0:92:F9
software-id: 45DI-BMH1 key:
w+RzyWCOwAeoxDV8qPTCZ8SwFlPzH6j3vO0WpM1JD9bZckk/3SAV66QMqO+TIh+Rgfu+v8/+Z/xXRLGd/tgHOA==
Waiting for installation server...
but when I press “install” on the Netinstall
I can see he “sending offer” and then nothing
the status change to “Blank” and then “Ready”
no firewall\antivirus is working on the computer Win7 SP1
on another computer its work .
but what could be the problem ?
I haven’t install anything on my computer , and even did system restore to 2 mounts ago (when I have use the Netinstall and it work)
I’ the administrator of the computer
and also i tries to run Netinstall as Administrator
firewall is disable
how can I see which socket is used ?
I know there is this command
netstat -an
where I can see Active connection
but how can I know which one Netinstall need to use ?
also after I have open Netinstall
I don’t see in the list the address of the RB ( the IP he got from the netinstall )
should I see it?
