Hello again .
I have a strange problem . When i paste some data at terminal i get the error " Router has been disconnected"
The paste data is the default script with some modification on ips and names .
Has any “protection” about how much lines i can paste?
I add it below to see it .
Thanks in advance .
/interface set ether1 name="Port1-Internet";
/ip dhcp-client add interface=Port1-Internet disabled=no comment="Auto-DHCP Client";
/interface set ether2 name=Port2-Hotspot;
/interface set ether3 name=Port3-Hotspot-Slave;
/interface set ether4 name=Port4-Hotspot-Slave;
/interface set ether5 name=Port5-Hotspot-Slave;
/interface ethernet set Port3-Hotspot-Slave master-port=Port2-Hotspot;
/interface ethernet set Port4-Hotspot-Slave master-port=Port2-Hotspot;
/interface ethernet set Port5-Hotspot-Slave master-port=Port2-Hotspot;
/ip address add address=192.168.200.1/24 interface=Port2-Hotspot comment="Hotspot Setup";
/ip pool add name="default-dhcp" ranges=192.168.200.10-192.168.200.254;
/ip dhcp-server add name=default address-pool="default-dhcp" interface=Port2-Hotspot disabled=no;
/ip dhcp-server network add address=192.168.200.0/24 gateway=192.168.200.1 dns-server=192.168.88.1 comment="Hotspot Setup";
/ip firewall nat add chain=srcnat out-interface=Port1-Internet action=masquerade comment="Hotspot Setup";
/ip firewall filter add chain=input action=accept protocol=icmp comment="Hotspot Setup";
/ip firewall filter add chain=input action=accept connection-state=established comment="Hotspot Setup";
/ip firewall filter add chain=input action=accept connection-state=related comment="Hotspot Setup";
/ip firewall filter add chain=input action=drop comment="Hotspot Setup" disabled=no in-interface=Port1-Internet;
/ip dns set allow-remote-requests=yes;
/ip dns static add name=router address=192.168.200.1;
