Hello.
I have just install my RB133 + R52H and one 2.4 Ghz disk antenna on main connector, ver. is 2.9.38.
My RB133 is a Station and signal from my AP at about 10 km from me is -65db.
I cannot register me but is it also strange that if I set from rxA-txA to rxB-txA, I see mine and other AP with a better signal of 10db (My AP is now -55db). Why ? I have not antenna on connector B.
Any idea ?
I have a couple RB133’s with the SR2s in them. I thought the main connector (MMCX) was ant-a, but I get very little input/output unless I switch to ant-b in the wireless setup. Tx and Rx got much better. Maybe it is just me…
The point was that the “main” transceiver on this chipset design appears to be the left connector. His “main” is also the left connector. Not all is as it appears.
EDIT: Strange that nothing has been mentioned on this forum since October about ant-a or ant-b being the selection for the MMCX connector on the SR2. And then nobody knew the answer. It has been out longer than the MikroTik radio, has it not?
I spent 30 minutes surfing this forum first before experimenting on my own. And it takes a few minutes to get far away enough to see if the change made any difference.
