I have a VPN client with LAN address 192.168.19.254/24 and VPN server with remote LAN address 192.168.14.254/24.
Let’s suppose that the VPN connection is established, but the server does not respond to ICMP requests.
Here is the actual (active) ipsec policy:
[admin@client] /ip ipsec policy> print
Flags: T - template, B - backup, X - disabled, D - dynamic, I - invalid, A - active, * - default
# PEER TUN SRC-ADDRESS DST-ADDRESS PROTOCOL ACTION
0 T * 0.0.0.0/0 0.0.0.0/0 all
1 A la.. yes 192.168.19.0/24 192.168.14.0/24 all encrypt
The connection is stable:
[admin@client] /ip ipsec active-peers> print
Flags: R - responder, N - natt-peer
# ID STATE UPTIME PH2-TOTAL REMOTE-ADDRESS DYNAMIC-ADDRESS
0 not.telling.com established 32m57s 1 89.134.111.123
When I try to do traceroute from client to server then I see this most of the time:
# ADDRESS LOSS SENT LAST AVG BEST WORST STD-DEV STATUS
1 100% 4 timeout
2 100% 4 timeout
3 100% 4 timeout
4 100% 4 timeout
5 100% 4 timeout
But sometimes this happens:
[admin@client] /ip route> /tool traceroute 192.168.14.254
1 89.134.243.1 56.. 16 timeout 0.1 0 0.1 0 host unreachable from 89.134.243.1
2 89.134.243.1 53.. 16 0ms 0 0 0 0 host unreachable from 89.134.243.1
3 89.134.243.1 13.. 15 0ms 77.1 0 986.2 262.4 host unreachable from 89.134.243.1
4 0% 0 0ms
E.g. sometimes I get “host unreachable from ” instead of a plain timeout.
The routing table on the client was created with:
add comment="Prevent package leak RFC1918 class A" distance=1 dst-address=10.0.0.0/8 type=unreachable
add comment="Prevent package leak RFC1918 class B" distance=1 dst-address=172.16.0.0/12 type=unreachable
add comment="Prevent package leak RFC1918 class C" distance=1 dst-address=192.168.0.0/16 type=unreachable
add comment="VPN to server" distance=1 dst-address=192.168.14.0/24 gateway=ipsec pref-src=192.168.19.254
The actual routing table is more difficult:
/ip route> print
Flags: X - disabled, A - active, D - dynamic, C - connect, S - static, r - rip, b - bgp, o - ospf, m - mme,
# DST-ADDRESS PREF-SRC GATEWAY DISTANCE
0 ADS 0.0.0.0/0 89.134.255.254 1
1 A SU ;;; Prevent package leak RFC1918 class A
10.0.0.0/8 1
2 ADC 10.19.10.0/24 10.19.10.1 BLUE_VLAN 0
3 ADC 10.19.20.0/24 10.19.20.1 GREEN_VLAN 0
4 ADC 10.19.30.0/24 10.19.30.1 RED_VLAN 0
5 ADC 89.134.240.0/20 89.134.243.1 ether5-wan 0
6 A SU ;;; Prevent package leak RFC1918 class B
172.16.0.0/12 1
7 A SU ;;; Prevent package leak RFC1918 class C
192.168.0.0/16 1
8 A S ;;; VPN to server
192.168.14.0/24 192.168.19.254 ipsec 1
9 ADC 192.168.19.0/24 192.168.19.254 BASE_VLAN 0
The “ipsec” bridge was specifically created to allow routing of to-be-esp-encapsulated packages:
add name=ipsec protocol-mode=none
The most specific route is the one that goes to the “ipsec” bridge:
If that fails, then the next most specific should be the unreachable static route - that was specifically created to prevent leaking such packages:
192.168.0.0/16 1
This route should always catch packages and prevent them from leaking out on the default gateway.
As far as I understand packet flow, the packets with 192.168.14.0/24 destination should leave the routing process towards the ipsec bridge, and the ESP encapsulation should happen after that.
So how does my router responds with “host unreachable” messages? And why it is undeterministic? (E.g. 90% of the time I get a timeout, and only in 10% I get a “host unreachable” message)?
