Hi all.
I have and old Sony PS3 box connected to Mikrotik and I see that dhcp-hostname which set from PS3 network options is showing strange symbols (I also updated PS3 to latest FW and still seeing incorrect dhcp-hostname).
From Winbox:
From ssh:
ps3\00
Webfig shows this lease with correct hostname, without any cubes or zeroes.
Anybody facing such symbols?
Thanks.
Looks like the PS3 DHCP client has an off-by-one error in the length of the hostname (the \00 is a null terminator that indicates the end of a string). Interesting bug, but completely harmless (DHCP client hostnames have no character set restrictions).
3.1. Name space definitions
Domain names in messages are expressed in terms of a sequence of labels.
Each label is represented as a one octet length field followed by that
number of octets. Since every domain name ends with the null label of
the root, a domain name is terminated by a length byte of zero. The
high order two bits of every length octet must be zero, and the
remaining six bits of the length field limit the label to 63 octets or
less.
To simplify implementations, the total length of a domain name (i.e.,
label octets and label length octets) is restricted to 255 octets or
less.
Although labels can contain any 8 bit values in octets that make up a
label, it is strongly recommended that labels follow the preferred
syntax described elsewhere in this memo, which is compatible with
existing host naming conventions. Name servers and resolvers must
compare labels in a case-insensitive manner (i.e., A=a), assuming ASCII
with zero parity. Non-alphabetic codes must match exactly.
