the RouterOS told me that there are syntax errors, it doesn’t like the “=” between local-address (remote-address) and the IP-address. Is that a issue in the firmware or is the wiki outdated? Is there any solution to fix the problem?
Current firmware: 3.1.9
Upgrade firmware: 3.1.8 (??)
Model: RB2011UiAS-RM
with 6.19 and recent 6.28rc and there’s no problem. But beware versions 6.20 and few more after that, because there was 6to4 mayhem which broke almost everything. It’s fixed in later versions, at least for your scenario with tunnelbroker.
While it’s most probably a RouterOS bug that’s already fixed, I think a workaround even in the buggy version would be to surround the name with quotes, e.g.
as I’m thinking maybe that RouterOS version interprets the “-1” as part of an arithmetic expression… It shouldn’t though (that’s why this is a bug non the less).
