So this is the situation.
I have 2 microwave links connecting a CCR1036 and a 1100ahx4
all 4 Ethernet ports is connecting 1Gbps full duplex with flow control enabled.
Lets say router A has 192.168.0.1/29 and B 192.168.0.4/29 ether 1
A 192.168.1.1/29 and B 192.168.1.4/29 ether 2
Then router b has on a different interface 192.168.100.1 just a example.
If i’m testing from 192.168.0.1 to 192.168.0.4 the link is doing its full speed on TCP, but when doing 192.168.0.1 to 192.168.100.1 the TCP speed is less then half.
I checked CPU usage on both sides during the test and it does not go above 5% on either router.
Any reason this happens ?
