strange Traffic issue
I use a CCR1036-12G-4S as Internet gateway. The customer connect across a bridged network via pppoe. For AAA i use a radius server.
To this point there a no problems, customer gets the bandwidth and IP assigned and can access the internet.
Now to the problem.
Some customers do not reach the allocated bandwidth, although other which are connected by the same AP are able to use the assigned bandwidth.
the connection of the antennas also offers enough performance to provide the bandwidth.
on the MT is set a NAT Rule as the customers receive addresses from 192.168.10.0/24.
Each customer get a simple Queue for bandwidth-management.
Did someone has an idea what it can be?
sry for my poor english :wink:
Dirk
Are you implying all customers are connected to the same physical AP and that some get their allotted bandwidth and some dont?
If so, there may be other physical issues at the AP level. I would not assume the issue is with the CCR/config.
The customer are conneting to different AP’s wich are finally connected to the MT.
But atm we switched back to the old config an give it a try later.
Dirk
