I’v been working with MT for some time now but i’v never seen this short of dataratevalue before?
5.5Mbps-SP/5.5Mbps-SP
usually it comes up something like this: 24Mbps/12Mbps
So my quastian is: what does the SP stands for?
One more thing: Since I’ve put up this AP all the clients have been complaining about the speed stability and so on.
Thanks.
In my config i configurd to “both”. I’v tried to set it to “long” and then SP disappears.
The AP is set too use B band. So what is the best config for this?
It is up to the clients - you need to make sure that you use option that all the clients support.
I suggest to upgrade your network to B/G or N if you want more performance.
