Strange voltage readings
I’m guessing that maybe this is 24V with a 100x offset (manual pages say something about 10x), but it’s a bit disconcerting and should be easy to fix.
Also, shouldn’t the health output include the system temperature?
[admin@MikroTik] > /system health print
  voltage: 2416.9V
[admin@MikroTik] > /system resource print
                   uptime: 3d12h4m51s
                  version: 5.5
              free-memory: 18608KiB
             total-memory: 29708KiB
                      cpu: MIPS 24Kc V7.4
                cpu-count: 1
            cpu-frequency: 680MHz
                 cpu-load: 3%
           free-hdd-space: 30828KiB
          total-hdd-space: 61440KiB
  write-sect-since-reboot: 163740
         write-sect-total: 785095
               bad-blocks: 0%
        architecture-name: mipsbe
               board-name: RB750G
                 platform: MikroTik
Firmware version is 2.29…
this device doesn’t have a voltage sensor. a software fix will disable this menu.
Still there in 5.6, not a big deal, but any idea where a fix would be on the road map?
Thanks!
