Hi all,
For MANET environment, I am trying to write a script to redefine the “Distance” of each WDS partner.
The fact is that with the static routes of the script (shown below) it seems to work.
The issue is when I make power-on to one node all the other nodes, which were already working, hang-off for some tenths of seconds.
Is this the normal behaviour for WDS?
Is there a turn-around for this behaviour?
Thanks.
J.A.R.Militão
# /system scheduler add name=Startup on-event=scrMESH start-time=startup interval=0
#/sys scr run test_script_2
:global scrMESH 1;
:local monLine;
:local number;
:local numbers;
:local gip;
:local dstip;
:local dstmac;
:local dstrssi;
:local distance;
:local MyNet;
:local ThisNet;
:local ThisGw;
:delay 20;
:local netArray {"192.168.0.0/24";"10.10.10.1"; \
"192.168.1.0/24";"10.10.10.1"; \
"192.168.2.0/24";"10.10.10.2"; \
"192.168.3.0/24";"10.10.10.3"; \
"192.168.4.0/24";"10.10.10.4"; \
"192.168.5.0/24";"10.10.10.5" \
:if ([:len [/ip route find where gateway="my_bridge"]] >0) do={
:set $MyNet [/ip route get [find gateway="my_bridge"] dst-address];
:put ("MyNet ".$MyNet);
:for e from 0 to ([len $netArray ]-1) step 2 do={
:put ("---".[:pick $netArray $e]);
:set $ThisNet [:pick $netArray $e];
: set $ThisGw [:pick $netArray ($e+1)];
: if ($MyNet != $ThisNet) do={
:put ("ThisNet ".$ThisNet." ThisGw ".$ThisGw );
/ip route add dst-address=$ThisNet gateway=$ThisGw distance=127
:do {
:put ("\r\n".[:system clock get date]." " .[:system clock get time]."----");
:for i from 2 to 3 do={
:put (" -----");
:set $gip ("10.10.10.".$i);
:if ([:len [/ip route find where gateway=$gip]] >0) do={
:local myArray [/ip route find where gateway=$gip];
:for e from 0 to ([len $myArray]-1) do={
#:put ($e.": ".[:pick $myArray $e]);
:set $number [:pick $myArray $e];
#:put (" numbers=".$e." number=".$number);
:set $dstip [/ip route get $number dst-address];
:set $distance [/ip route get $number distance];
:put ("'ip route' says "." for ".$dstip." gateway: ".$gip." distance=".$distance);
:if ([:len [/ip arp find where address=$gip]] >0) do={
:set $dstmac [/ip arp get [find address=$gip] mac-address];
#:put ("from 'ip arp' MAC=".$dstmac);
:if ([:len [/interface wireless registration-table find where mac-address=$dstmac]] >0) do={
:set $dstrssi [/interface wireless registration-table get [ find mac-address=$dstmac] signal-strength];
#:put ("from 'interface wireless registration-table' RSSI=".$dstrssi);
:set $signal [:pick $dstrssi 0 [:find $dstrssi "@"]];
:set $speed [:pick $dstrssi ([:find $dstrssi "@"]+1) [:len $dstrssi]];
:put (" dst ".$dstip." gw=". $gip." mac=".$dstmac." signal=".$signal." speed=".$speed);
:local value [:pick $signal 0 ([:find $signal "dBm"])];
#:put (" value=".$value);
#:put (" new dist=".($value*-1));
:set [/ip route set $number distance= ($value*-1)];
:delay 1;
} while=($scrMESH = 1);
/ip route remove [find dst-address=$ThisNet gateway=$ThisGw]
