strange wlan-problems (6.4)
Hey Guys,
Maybe you can give me some hints on my very very strange wifi-problem.
Since a few days i’m no longer able to connect to my mikrotik-wifi with my dell notebook. All other devices we have in our apartment works well (iPhone, iPad …)
I always get some very strange error messages in logging when i try to connect with my notebook like this:
Oct/11/2013 05:30:17 wireless,debug WIFI: 84:3A:4B:1B:13:A8 attempts to associate
Oct/11/2013 05:30:17 wireless,debug WIFI: 84:3A:4B:1B:13:A8 not in local ACL, by default accept
Oct/11/2013 05:30:17 wireless,info 84:3A:4B:1B:13:A8@WIFI: connected
Oct/11/2013 05:30:18 wireless,debug WIFI: 84:3A:4B:1B:13:A8 attempts to associate
Oct/11/2013 05:30:18 wireless,info 84:3A:4B:1B:13:A8@WIFI: reassociating
Oct/11/2013 05:30:18 wireless,info 84:3A:4B:1B:13:A8@WIFI: disconnected, ok
Oct/11/2013 05:30:18 wireless,debug WIFI: 84:3A:4B:1B:13:A8 not in local ACL, by default accept
Oct/11/2013 05:30:18 wireless,info 84:3A:4B:1B:13:A8@WIFI: connected
Oct/11/2013 05:30:19 wireless,debug WIFI: 84:3A:4B:1B:13:A8 attempts to associate
Oct/11/2013 05:30:19 wireless,info 84:3A:4B:1B:13:A8@WIFI: reassociating
Oct/11/2013 05:30:19 wireless,info 84:3A:4B:1B:13:A8@WIFI: disconnected, ok
Oct/11/2013 05:30:19 wireless,debug WIFI: 84:3A:4B:1B:13:A8 not in local ACL, by default accept
Oct/11/2013 05:30:19 wireless,info 84:3A:4B:1B:13:A8@WIFI: connected
[color=#FF0000]Oct/11/2013 05:30:23 wireless,info 84:3A:4B:1B:13:A8@WIFI: disconnected, extensive data loss[/color]
So i don’t think that my wireless card in my notebook does have some kind of error because the wifi-connection works on every other place (working company, cafes, mc donalds …)
in an other post i found at google there was an hint to reduce the tx-power (maybe to near to the ap - my router is under my working table so the notebook is directly above - maybe 30-40cm distant) but that also does not help anything.
as an additional information: my notebook is equipped with an intel centrino advanced-n 6205 chipset.
So actually i’m at one’s wits’ end so maybe you have any hints or in the best case some solutions for me :wink:
kind Regards
Florian
when you see in the registration table when you connect. as it seems you are connected for some time. Check signal levels.
Hey,
First: Thanks for reply.
I’m not shure if i understood this correctly. You mean to check signal levels exactly at this moment when my notebook is connected?
Kind Regards
when the notebook is connected i see following signal strengh in screenshot (attachment).
Regards
Hey Guys,
So upgrade to 6.5 solved the problem without changing anything at the config.
Kind regards
