Streaming IPTV
I’m having issues streaming IPTV, I get stream not available. I’ve moved it back to the old router and it works good no issues getting streams. Its only require port 80,443,DNS OUT to the internet. So not sure why its not able to get any stream
add address=192.168.88.11/32 dns-server=1.0.0.1,1.1.1.1 gateway=192.168.88.1 netmask=24
set allow-remote-requests=yes mdns-repeat-ifaces=bridge servers=1.1.1.1,1.0.0.1 use-doh-server=https://1.1.1.1/dns-query verify-doh-cert=yes
/ip dns static
add address=192.168.88.1 comment=defconf name=router.lan type=A
/ip firewall address-list
add address=192.168.88.0/24 comment=“FW Admin” list=fwadmin
add address=4.2.2.2 comment=DNS list=P3_DNS
add action=accept chain=forward src-address=192.168.88.11
add action=fasttrack-connection chain=forward comment=“defconf: fasttrack” connection-state=established,related hw-offload=yes
add action=accept chain=forward comment=“defconf: accept established,related, untracked” connection-state=established,related,untracked
add action=accept chain=forward comment=“Internet in LAN Out WAN” in-interface-list=LAN out-interface-list=WAN
add action=accept chain=input comment=“fw admin” dst-address=192.168.88.1 dst-address-list=fwadmin log=yes
add action=accept chain=input comment=“defconf: accept established,related,untracked” connection-state=established,related,untracked
add action=drop chain=input comment=“defconf: drop invalid” connection-state=invalid log=yes
add action=accept chain=input comment=“defconf: accept ICMP” disabled=yes protocol=icmp
add action=accept chain=input comment=“defconf: accept to local loopback (for CAPsMAN)” dst-address=127.0.0.1
add action=drop chain=input comment=“defconf: drop all not coming from LAN” in-interface-list=!LAN
add action=accept chain=forward comment=“defconf: accept in ipsec policy” connection-mark=“” connection-nat-state=“” connection-state=“” connection-type=“” ipsec-policy=
in,ipsec packet-mark=“” routing-mark=main
add action=accept chain=forward comment=“defconf: accept out ipsec policy” ipsec-policy=out,ipsec
add action=drop chain=forward comment=“Implicit Drop Forward Chan” connection-state=invalid log=yes log-prefix=IMPLICIT
add action=drop chain=forward comment=“defconf: drop all from WAN not DSTNATed” connection-nat-state=!dstnat connection-state=new in-interface-list=WAN
add action=masquerade chain=srcnat comment=“defconf: masquerade” ipsec-policy=out,none out-interface-list=WAN
add action=redirect chain=dstnat comment=DNS dst-port=53 protocol=udp src-address=!192.168.88.11 to-ports=53
add action=redirect chain=dstnat dst-port=53 protocol=udp to-ports=53
add action=redirect chain=dstnat dst-port=53 protocol=tcp to-ports=53
/ip hotspot profile
/ip ipsec profile
add check-gateway=ping comment=P3RTR disabled=no dst-address=192.168.88.11 gateway=192.168.88.1 routing-table=main suppress-hw-offload=no
/ip service
set telnet disabled=yes
/ip smb shares
set [ find default=yes ] directory=pub
/ip ssh
set always-allow-password-login=yes host-key-size=4096 strong-crypto=yes
/ip traffic-flow
set enabled=yes
/ipv6 firewall address-list
add address=::/128 comment=“defconf: unspecified address” list=bad_ipv6
add address=::1/128 comment=“defconf: lo” list=bad_ipv6
add address=fec0::/10 comment=“defconf: site-local” list=bad_ipv6
add address=::ffff:0.0.0.0/96 comment=“defconf: ipv4-mapped” list=bad_ipv6
add address=::/96 comment=“defconf: ipv4 compat” list=bad_ipv6
add address=2001:db8::/32 comment=“defconf: documentation” list=bad_ipv6
add address=2001:10::/28 comment=“defconf: ORCHID” list=bad_ipv6
add address=3ffe::/16 comment=“defconf: 6bone” list=bad_ipv6
/ipv6 firewall filter
add action=accept chain=input comment=“defconf: accept ICMPv6” protocol=icmpv6
add action=accept chain=input comment=“defconf: accept UDP traceroute” port=33434-33534 protocol=udp
add action=accept chain=input comment=“defconf: accept DHCPv6-Client prefix delegation.” dst-port=546 protocol=udp src-address=fe80::/10
add action=accept chain=input comment=“defconf: accept IKE” dst-port=500,4500 protocol=udp
add action=accept chain=input comment=“defconf: accept ipsec AH” protocol=ipsec-ah
add action=accept chain=input comment=“defconf: accept ipsec ESP” protocol=ipsec-esp
add action=accept chain=input comment=“defconf: accept all that matches ipsec policy” ipsec-policy=in,ipsec
add action=drop chain=input comment=“defconf: drop everything else not coming from LAN” in-interface-list=!LAN
add action=accept chain=forward comment=“defconf: accept established,related,untracked” connection-state=established,related,untracked
add action=drop chain=forward comment=“defconf: drop invalid” connection-state=invalid
add action=drop chain=forward comment=“defconf: drop packets with bad src ipv6” src-address-list=bad_ipv6
add action=drop chain=forward comment=“defconf: drop packets with bad dst ipv6” dst-address-list=bad_ipv6
add action=drop chain=forward comment=“defconf: rfc4890 drop hop-limit=1” hop-limit=equal:1 protocol=icmpv6
add action=accept chain=forward comment=“defconf: accept ICMPv6” protocol=icmpv6
add action=accept chain=forward comment=“defconf: accept HIP” protocol=139
add action=accept chain=forward comment=“defconf: accept IKE” dst-port=500,4500 protocol=udp
add action=accept chain=forward comment=“defconf: accept ipsec AH” protocol=ipsec-ah
add action=accept chain=forward comment=“defconf: accept ipsec ESP” protocol=ipsec-esp
add action=accept chain=forward comment=“defconf: accept all that matches ipsec policy” ipsec-policy=in,ipsec
add action=drop chain=forward comment=“defconf: drop everything else not coming from LAN” in-interface-list=!LAN
