How can i stream a packet capture from Router OS to a Wireshark PC?
I can’t figure out how to properly config Wireshark to receive a stream.
Thank you
Thank you
Read about port mirroring.
https://help.mikrotik.com/docs/display/ROS/Switch+Chip+Features#SwitchChipFeatures-PortMirroring
Port mirroring is not an option, Im need to do a remote capture, without visiting the site, Right now i do a local capture inside the router os then copy file via winbox . that is a little slow. i was trying to figure out how to use the packet sniffer streaming feature
Google is your best friend and it’s free! ![]()
