Strip a certain VLAN ID on egress....
Gentleman, im at wits end here. I need to remove the Vlan tag upon a certain vlan when it exits out port 5. BUT i have 2 other VLANS that need to keep their id upon exiting this port…Any ideas on how to acomplish this?
I have a trunk of 4 VLANS running into port 1 of a 250GS.
VLAN 50: ------> goes to ----> ports 4 and 5 BUT want to strip the tag from Vlan 50 so the unifi AP see it! BUT only strip the tag from vlan 50!
VLAN 51: ------> goes to ----> ports 2 and 3 (Strips tags on exit)
Vlan 52: -----> goes to -----> port 4 and 5 (need it to keep the vlan ID upon exiting the switch)
Vlan 53: -----> goes to -----> port 4 and 5 (need it to keep the vlan ID upon exiting the switch)
In case your wondering this is a network that runs in our building. I have an rb1100 in the basement with vlans 50,51,52, and 53 on it, that has a dumb switch connected to it. Off this dumb switch each floor has an ethernet run to a rb250gs. On each floor we use ports 2 and 3 for wired customers, and ports 4 and 5 for our ubiqui UniFI access points. The access points i want on vlan 50 but they support 2 seperate SSID’s, and i have one set to run on VLAN 51 and one set for VLAN 52…hence the problem why i need to do this. The AP itself needs to be on vlan 50, but has to see this untaged…since there is no way to set a vlan id for the AP’s main IP.
Hope someone can figure this one out!
–John
You might be able to do this using the ACL feature of the 250GS.
Packets coming into the port matching the mac address of the AP management interface get a new vlan id of 50 assigned.
Packets leaving the port going to the mac address of the AP management interface get the vlan stripped (assigned to ‘0’ I think is the correct way to do this).
I did this once, but I’d have to find the switch and log into it to remember how I did it.
Generally, the hardware lacks the feature of using Cisco-speaking ‘native vlan’ in trunked more.
I hope that you can setup the unifi ap to talk with it’s own VLAN-tag for its management.
