Strong signal, but still disconnecting
I have two points that seem very healthy, yet they tend to disconnect several times a day. Please Help.
Site A: RB433AH + XR9 ROS V4.10 12db Sector Antenna
Site B: RB433AH + XR9 ROS V4.10 12db Rootenna Patch Antenna
2Ghz-10Mhz
Noise Floor: (A)-92dbm (B)-87dbm
Signal Strng: (A)-69dbm (B)-68dbm
SNR: Both get between 20 and 25
Data Rate: Is currently Statically set at 6mb
Both set to “ap bridge” and use WDS
I have set Tx Power to 15dBm. Default is 18dBm (At default they seem to over power each other, Signal in the 50s)
Minimum LOS obstructions about 2.5 miles apart
Here is a sample of the Log on Site B:
Jul/21/2010 12:55:36 wireless,info 00:15:XX:XX:XX:55@wlan1: disconnected, received deauth: class 2 frame received (6)
Jul/21/2010 12:55:49 wireless,debug wlan1: 00:15:XX:XX:XX:55 attempts to associate
Jul/21/2010 12:55:49 wireless,info 00:15:XX:XX:XX:55@wlan1: connected, is AP, wants WDS
Jul/21/2010 12:55:49 wireless,debug wlan1: failed to set bridge port for wlan1, reason: device already added as bridge port (6)
Jul/21/2010 14:01:03 wireless,info 00:15:XX:XX:XX:55@wlan1: disconnected, received deauth: class 2 frame received (6)
Jul/21/2010 14:01:08 wireless,debug wlan1: 00:15:XX:XX:XX:55 attempts to associate
Jul/21/2010 14:01:08 wireless,info 00:15:XX:XX:XX:55@wlan1: connected, is AP, wants WDS
Jul/21/2010 14:01:08 wireless,debug wlan1: failed to set bridge port for wlan1, reason: device already added as bridge port (6)
Jul/21/2010 14:01:18 wireless,info 00:15:XX:XX:XX:55@wlan1: disconnected, received deauth: class 2 frame received (6)
Jul/21/2010 14:01:22 wireless,debug wlan1: 00:15:XX:XX:XX:55 attempts to associate
Jul/21/2010 14:01:22 wireless,info 00:15:XX:XX:XX:55@wlan1: connected, is AP, wants WDS
Jul/21/2010 14:01:22 wireless,debug wlan1: failed to set bridge port for wlan1, reason: device already added as bridge port (6)
Jul/21/2010 16:09:57 system,info,account user admin logged in from 192.168.1.126 via winbox
Jul/21/2010 16:11:58 wireless,info 00:15:XX:XX:XX:55@wlan1: disconnected, received deauth: class 2 frame received (6)
Jul/21/2010 16:12:13 wireless,debug wlan1: 00:15:XX:XX:XX:55 attempts to associate
Jul/21/2010 16:12:13 wireless,info 00:15:XX:XX:XX:55@wlan1: connected, is AP, wants WDS
Jul/21/2010 16:12:13 wireless,debug wlan1: failed to set bridge port for wlan1, reason: device already added as bridge port (6)
Jul/21/2010 16:12:19 system,info,account user admin logged out from 192.168.1.126 via winbox
Jul/21/2010 18:22:09 wireless,info 00:15:XX:XX:XX:55@wlan1: disconnected, received deauth: class 2 frame received (6)
Jul/21/2010 18:22:21 wireless,debug wlan1: 00:15:XX:XX:XX:55 attempts to associate
Jul/21/2010 18:22:21 wireless,info 00:15:XX:XX:XX:55@wlan1: connected, is AP, wants WDS
Jul/21/2010 18:22:21 wireless,debug wlan1: failed to set bridge port for wlan1, reason: device already added as bridge port (6)
Jul/21/2010 19:27:39 wireless,info 00:15:XX:XX:XX:55@wlan1: disconnected, received deauth: class 2 frame received (6)
Jul/21/2010 19:27:49 wireless,debug wlan1: 00:15:XX:XX:XX:55 attempts to associate
Jul/21/2010 19:27:49 wireless,info 00:15:XX:XX:XX:55@wlan1: connected, is AP, wants WDS
Jul/21/2010 19:27:49 wireless,debug wlan1: failed to set bridge port for wlan1, reason: device already added as bridge port (6)
Jul/21/2010 21:48:51 wireless,info 00:15:XX:XX:XX:55@wlan1: disconnected, received deauth: class 2 frame received (6)
Jul/21/2010 21:49:08 wireless,debug wlan1: 00:15:XX:XX:XX:55 attempts to associate
Jul/21/2010 21:49:08 wireless,info 00:15:XX:XX:XX:55@wlan1: connected, is AP, wants WDS
Jul/21/2010 21:49:08 wireless,debug wlan1: failed to set bridge port for wlan1, reason: device already added as bridge port (6)
Jul/21/2010 23:04:16 wireless,info 00:15:XX:XX:XX:55@wlan1: disconnected, received deauth: class 2 frame received (6)
Jul/21/2010 23:04:24 wireless,debug wlan1: 00:15:XX:XX:XX:55 attempts to associate
Jul/21/2010 23:04:24 wireless,info 00:15:XX:XX:XX:55@wlan1: connected, is AP, wants WDS
Jul/21/2010 23:04:24 wireless,debug wlan1: failed to set bridge port for wlan1, reason: device already added as bridge port (6)
Jul/21/2010 23:20:37 wireless,info 00:15:XX:XX:XX:55@wlan1: disconnected, received deauth: class 2 frame received (6)
Jul/21/2010 23:21:18 wireless,debug wlan1: 00:15:XX:XX:XX:55 attempts to associate
Jul/21/2010 23:21:18 wireless,info 00:15:XX:XX:XX:55@wlan1: connected, is AP, wants WDS
Jul/21/2010 23:21:18 wireless,debug wlan1: failed to set bridge port for wlan1, reason: device already added as bridge port (6)
Jul/21/2010 23:21:37 wireless,info 00:15:XX:XX:XX:55@wlan1: disconnected, received deauth: class 2 frame received (6)
Jul/21/2010 23:23:36 wireless,debug wlan1: 00:15:XX:XX:XX:55 attempts to associate
Jul/21/2010 23:23:36 wireless,info 00:15:XX:XX:XX:55@wlan1: connected, is AP, wants WDS
Jul/21/2010 23:23:37 wireless,debug wlan1: failed to set bridge port for wlan1, reason: device already added as bridge port (6)
Jul/21/2010 23:23:47 wireless,info 00:15:XX:XX:XX:55@wlan1: disconnected, received deauth: class 2 frame received (6)
Jul/21/2010 23:24:29 wireless,debug wlan1: 00:15:XX:XX:XX:55 attempts to associate
Jul/21/2010 23:24:29 wireless,info 00:15:XX:XX:XX:55@wlan1: connected, is AP, wants WDS
Jul/21/2010 23:24:29 wireless,debug wlan1: failed to set bridge port for wlan1, reason: device already added as bridge port (6)
Jul/22/2010 00:49:05 wireless,debug wlan1: 00:15:6D:94:2D:1A attempts to associate
Jul/22/2010 00:49:05 wireless,info wlan1: data from unknown device 00:15:6D:94:2D:1A, sent deauth
Jul/22/2010 01:40:04 wireless,info 00:15:XX:XX:XX:55@wlan1: disconnected, received deauth: class 2 frame received (6)
Jul/22/2010 01:40:14 wireless,debug wlan1: 00:15:XX:XX:XX:55 attempts to associate
Jul/22/2010 01:40:14 wireless,info 00:15:XX:XX:XX:55@wlan1: connected, is AP, wants WDS
Jul/22/2010 01:40:14 wireless,debug wlan1: failed to set bridge port for wlan1, reason: device already added as bridge port (6)
Jul/22/2010 03:00:20 wireless,info 00:15:XX:XX:XX:55@wlan1: disconnected, received deauth: class 2 frame received (6)
Jul/22/2010 03:00:39 wireless,debug wlan1: 00:15:XX:XX:XX:55 attempts to associate
Jul/22/2010 03:00:39 wireless,info 00:15:XX:XX:XX:55@wlan1: connected, is AP, wants WDS
Jul/22/2010 03:00:39 wireless,debug wlan1: failed to set bridge port for wlan1, reason: device already added as bridge port (6)
Jul/22/2010 05:43:20 wireless,info 00:15:XX:XX:XX:55@wlan1: disconnected, received deauth: class 2 frame received (6)
Jul/22/2010 05:43:36 wireless,debug wlan1: 00:15:XX:XX:XX:55 attempts to associate
Jul/22/2010 05:43:36 wireless,info 00:15:XX:XX:XX:55@wlan1: connected, is AP, wants WDS
Jul/22/2010 05:43:36 wireless,debug wlan1: failed to set bridge port for wlan1, reason: device already added as bridge port (6)
Jul/22/2010 07:05:05 wireless,info 00:15:XX:XX:XX:55@wlan1: disconnected, received deauth: class 2 frame received (6)
Jul/22/2010 07:05:22 wireless,debug wlan1: 00:15:XX:XX:XX:55 attempts to associate
Jul/22/2010 07:05:22 wireless,info 00:15:XX:XX:XX:55@wlan1: connected, is AP, wants WDS
Jul/22/2010 07:05:22 wireless,debug wlan1: failed to set bridge port for wlan1, reason: device already added as bridge port (6)
Jul/22/2010 08:24:10 wireless,info 00:15:XX:XX:XX:55@wlan1: disconnected, received deauth: class 2 frame received (6)
Jul/22/2010 08:24:24 wireless,debug wlan1: 00:15:XX:XX:XX:55 attempts to associate
Jul/22/2010 08:24:24 wireless,info 00:15:XX:XX:XX:55@wlan1: connected, is AP, wants WDS
Jul/22/2010 08:24:25 wireless,debug wlan1: failed to set bridge port for wlan1, reason: device already added as bridge port (6)
Jul/22/2010 08:47:36 wireless,info 00:15:XX:XX:XX:55@wlan1: disconnected, received deauth: class 2 frame received (6)
Jul/22/2010 08:49:41 wireless,debug wlan1: 00:15:XX:XX:XX:55 attempts to associate
Jul/22/2010 08:49:41 wireless,info 00:15:XX:XX:XX:55@wlan1: connected, is AP, wants WDS
Jul/22/2010 08:49:41 wireless,debug wlan1: failed to set bridge port for wlan1, reason: device already added as bridge port (6)
Jul/22/2010 08:49:59 wireless,info 00:15:XX:XX:XX:55@wlan1: disconnected, received deauth: class 2 frame received (6)
Jul/22/2010 08:50:26 wireless,debug wlan1: 00:15:XX:XX:XX:55 attempts to associate
Jul/22/2010 08:50:26 wireless,info 00:15:XX:XX:XX:55@wlan1: connected, is AP, wants WDS
Jul/22/2010 08:50:26 wireless,debug wlan1: failed to set bridge port for wlan1, reason: device already added as bridge port (6)
Jul/22/2010 08:50:39 wireless,info 00:15:XX:XX:XX:55@wlan1: disconnected, received deauth: class 2 frame received (6)
Jul/22/2010 08:51:53 wireless,debug wlan1: 00:15:XX:XX:XX:55 attempts to associate
Jul/22/2010 08:51:53 wireless,info 00:15:XX:XX:XX:55@wlan1: connected, is AP, wants WDS
Jul/22/2010 08:51:53 wireless,debug wlan1: failed to set bridge port for wlan1, reason: device already added as bridge port (6)
Jul/22/2010 08:52:03 wireless,info 00:15:XX:XX:XX:55@wlan1: disconnected, received deauth: class 2 frame received (6)
Jul/22/2010 08:52:04 wireless,debug wlan1: 00:15:XX:XX:XX:55 attempts to associate
Jul/22/2010 08:52:04 wireless,info 00:15:XX:XX:XX:55@wlan1: connected, is AP, wants WDS
Jul/22/2010 08:52:04 wireless,debug wlan1: failed to set bridge port for wlan1, reason: device already added as bridge port (6)
Jul/22/2010 09:34:54 wireless,info 00:15:XX:XX:XX:55@wlan1: disconnected, received deauth: class 2 frame received (6)
Jul/22/2010 09:35:09 wireless,debug wlan1: 00:15:XX:XX:XX:55 attempts to associate
Jul/22/2010 09:35:09 wireless,info 00:15:XX:XX:XX:55@wlan1: connected, is AP, wants WDS
Jul/22/2010 09:35:09 wireless,debug wlan1: failed to set bridge port for wlan1, reason: device already added as bridge port (6)
Jul/22/2010 10:43:48 wireless,info 00:15:XX:XX:XX:55@wlan1: disconnected, received deauth: class 2 frame received (6)
Jul/22/2010 10:43:57 wireless,debug wlan1: 00:15:XX:XX:XX:55 attempts to associate
Jul/22/2010 10:43:57 wireless,info 00:15:XX:XX:XX:55@wlan1: connected, is AP, wants WDS
Jul/22/2010 10:43:57 wireless,debug wlan1: failed to set bridge port for wlan1, reason: device already added as bridge port (6)
Jul/22/2010 11:50:49 wireless,info 00:15:XX:XX:XX:55@wlan1: disconnected, received deauth: class 2 frame received (6)
Jul/22/2010 11:50:50 wireless,debug wlan1: 00:15:XX:XX:XX:55 attempts to associate
Jul/22/2010 11:50:50 wireless,info 00:15:XX:XX:XX:55@wlan1: connected, is AP, wants WDS
I’m noticing some people are having issues with WDS. Would I be better off doing a PTMP bridge? Site A is connecting to several other access points.
