Hi all, i’ve just been trying to learn scripting mikrotik, in example i want to know about after send file via email to my mail and then after the file sent from mikrotik the file will be delete automatically, i’ve been trying this way:
the simple code above not work even the mail not sending, what i must to do in scripting mikrotik to run the first command i want and do another command after the first command is finished and work, and for running script on scheduler how can i do that it is just use notepad on windows and save the file to .rsc and upload via ftp can it work using that way ?
Thank’s for your reply janisk, but if you don’t mind could you please explain more detail to me, cause i’m bit confused about that.
A little example will help me a lot.
I’m sorry if this thing disturb your time, thank you.
