I’ve followed the wiki page here https://wiki.mikrotik.com/wiki/Manual:The_Dude_v6/The_Dude_server_on_hEX_RB750Gr3 to set the dude to store its database on the SD card, but after rebooting the router 1 of 2 things happen, If I use exactly the same folder name of “disk1/dude-data” then i’ll continually get something along the lines of “could not read data folder” (I don’t recall the exact message) and if I open the files list in winbox I only see the disk1 folder but no dude files at all underneath
Or if I use the folder “microsd” then upon reboot almost everything is missing from the dude, all the images etc, only the database file is present
So can someone shed some light on this? I’ve tried uninstalling and reinstalling the dude package 3 times, reformatting the microSD card as many times, tried various different folders. The only structure that properly works is using flash, but then after a reboot the database is completely wiped so its no good for me at all…
This HEX router is in an environment that will experience frequent power loss and needs to come back online. It will generally have a fixed database that very rarely changes, but when its set it has to be reliable where it can lose power, restarts again and all should just work as it was before
