Struggling with IPv6 and Container
I can’t figure out how to set up IPv6 to communicate with a container. IPv4 works perfectly but no ping for IPv6. Config attached.
Any idea what I’m doing wrong?
# 2024-05-03 17:01:07 by RouterOS 7.14.2
# software id = 4SAD-K293
# model = RB5009UG+S+
# serial number = HE408Z9RT61
add name="Local Bridge" port-cost-mode=short
add name=dockers port-cost-mode=short
set [ find default-name=ether1 ] name="Port 1 - Study"
set [ find default-name=ether2 ] name="Port 2 - Girl's Room"
set [ find default-name=ether3 ] name="Port 3 - Living Room"
set [ find default-name=ether4 ] name="Port 4 - Snug"
set [ find default-name=ether5 ] name="Port 5 - Bonded"
set [ find default-name=ether6 ] name="Port 6 - Bonded"
set [ find default-name=ether7 ] name="Port 7 - Kitchen"
set [ find default-name=ether8 ] mtu=1508 name="Port 8 - WAN"
set [ find default-name=sfp-sfpplus1 ] name="Port 9 - SFP+"
/interface pppoe-client
add add-default-route=yes disabled=no interface="Port 8 - WAN" max-mru=1500 \
    max-mtu=1500 name=Vodafone service-name="Vodafone PPPOE" use-peer-dns=yes \
    user=xxx@broadband.vodafone.co.uk
/interface veth
add address="" gateway=172.17.0.1 gateway6=fe80::c4b1:8cff:fe00:1 name=veth1
add address=172.17.0.2/24,fe80::c4b1:8cff:fe00:2/96 gateway=172.17.0.1 \
/interface wireguard
add comment=back-to-home-vpn listen-port=12713 mtu=1420 name=back-to-home-vpn
add listen-port=13231 mtu=1420 name=wireguard1
/interface bonding
add mode=802.3ad name="Bonded NAS" slaves="Port 5 - Bonded,Port 6 - Bonded" \
    transmit-hash-policy=layer-3-and-4
/container mounts
add dst=/etc/dnsmasq.d name=dnsmasq_pihole src=\
    /usb1-part1/pihole/etc-dnsmasq.d
add dst=/etc/pihole name=etc_pihole src=/usb1-part1/pihole/etc
add dst=/etc/dnsmasq.d name=dnsmasq_pihole2 src=\
    /usb1-part1/pihole2/etc-dnsmasq.d
add dst=/etc/pihole name=etc_pihole2 src=/usb1-part1/pihole2/etc
/disk
add parent=usb1 partition-number=1 partition-offset=512 partition-size=\
    "128 035 675 648" type=partition
add name=listBridge
add name=WAN
add comment=defconf include=listBridge name=LAN
/ip firewall layer7-protocol
add comment="Selects for YouTube traffic" name="YouTube L7" regexp=\
    "^..+\\.(youtube.com|googlevideo.com|akamaihd.net).*\$"
/ip ipsec mode-config
add connection-mark=ipsec name=NordVPN responder=no
/ip ipsec policy group
add name=NordVPN
/ip ipsec profile
add name=NordVPN
/ip ipsec peer
add address=uk2093.nordvpn.com exchange-mode=ike2 name=NordVPN profile=\
    NordVPN
/ip ipsec proposal
add name=NordVPN pfs-group=none
add name=dhcp_pool0 ranges=10.160.100.20-10.160.100.200
add address-pool=dhcp_pool0 interface="Local Bridge" lease-time=10m name=\
    dhcp1
/ip smb users
add name=Darren
/caps-man manager
set enabled=yes
/container
add envlist=pihole_envs interface=veth1 logging=yes mounts=\
    dnsmasq_pihole2,etc_pihole2 root-dir=/usb1-part1/pihole2 start-on-boot=\
    yes
/container config
set registry-url=https://registry-1.docker.io tmpdir="usb1-part1/pull "
/container envs
add key=TZ name=pihole_envs value=Europe/London
add key=WEBPASSWORD name=pihole_envs value=Ham1sh01
add key=DNSMASQ_USER name=pihole_envs value=root
/ip smb
set domain=WORKGROUP enabled=yes interfaces="Local Bridge"
add bridge="Local Bridge" interface="Port 2 - Girl's Room" \
    internal-path-cost=10 path-cost=10
add bridge="Local Bridge" interface="Port 1 - Study" internal-path-cost=10 \
    path-cost=10
add bridge="Local Bridge" interface="Port 7 - Kitchen" internal-path-cost=10 \
    path-cost=10
add bridge="Local Bridge" interface="Port 9 - SFP+" internal-path-cost=10 \
    path-cost=10
add bridge="Local Bridge" interface="Bonded NAS" internal-path-cost=10 \
    path-cost=10
add bridge="Local Bridge" interface="Port 3 - Living Room" \
add bridge="Local Bridge" interface="Port 4 - Snug" internal-path-cost=10 \
    path-cost=10
add bridge=dockers interface=veth1 internal-path-cost=10 path-cost=10
set udp-timeout=10s
set discover-interface-list=listBridge
/interface detect-internet
set detect-interface-list=WAN
add interface="Local Bridge" list=listBridge
add interface=Vodafone list=WAN
add interface="Port 8 - WAN" list=WAN
add address=10.160.100.1/24 interface="Local Bridge" network=10.160.100.0
add address=192.168.10.1/24 comment=WireGuard1 interface=wireguard1 network=\
    192.168.10.0
add address=172.17.0.1/24 comment="Docker container address range" interface=\
    dockers network=172.17.0.0
/ip cloud
set back-to-home-vpn=enabled ddns-enabled=yes ddns-update-interval=10m
/ip dhcp-server lease
add address=10.160.100.30 client-id=1:0:11:32:b7:b2:15 mac-address=\
    00:11:32:B7:B2:15 server=dhcp1
add address=10.160.100.68 client-id=1:ec:71:db:2e:8c:e0 mac-address=\
    EC:71:DB:2E:8C:E0 server=dhcp1
add address=10.160.100.85 client-id=1:6c:3b:6b:7e:ad:ee mac-address=\
    6C:3B:6B:7E:AD:EE server=dhcp1
add address=10.160.100.0/24 dns-server=10.160.100.1 gateway=10.160.100.1
set allow-remote-requests=yes cache-size=8192KiB max-concurrent-queries=1000 \
    max-concurrent-tcp-sessions=2000 servers=\
    1.1.1.3,1.0.0.3,2606:4700:4700::1113,2606:4700:4700::1003 use-doh-server=\
    https://family.cloudflare-dns.com/dns-query verify-doh-cert=yes
/ip dns static
add address=104.16.249.249 name=cloudflare-dns.com
add address=104.16.248.249 name=cloudflare-dns.com
/ip firewall address-list
add address=0.0.0.0/8 comment=RFC6890 list=not_in_internet
add address=172.16.0.0/12 comment=RFC6890 list=not_in_internet
add address=192.168.0.0/16 comment=RFC6890 list=not_in_internet
add address=10.0.0.0/8 comment=RFC6890 list=not_in_internet
add address=169.254.0.0/16 comment=RFC6890 list=not_in_internet
add address=127.0.0.0/8 comment=RFC6890 list=not_in_internet
add address=224.0.0.0/4 comment=Multicast list=not_in_internet
add address=198.18.0.0/15 comment=RFC6890 list=not_in_internet
add address=192.0.0.0/24 comment=RFC6890 list=not_in_internet
add address=192.0.2.0/24 comment=RFC6890 list=not_in_internet
add address=198.51.100.0/24 comment=RFC6890 list=not_in_internet
add address=203.0.113.0/24 comment=RFC6890 list=not_in_internet
add address=100.64.0.0/10 comment=RFC6890 list=not_in_internet
add address=240.0.0.0/4 comment=RFC6890 list=not_in_internet
add address=192.88.99.0/24 comment="6to4 relay Anycast [RFC 3068]" list=\
    not_in_internet
add address=10.160.100.30 list=VPN
    "accept established, related, untracked" connection-state=\
    established,related,untracked
add action=drop chain=input comment="Drop invalid" connection-state=invalid
add action=accept chain=input comment="accept ICMP" protocol=icmp
add action=accept chain=input comment="Accept LAN traffic" in-interface=\
    "Local Bridge"
add action=accept chain=input comment="Allow Wireguard" dst-port=13231 \
    protocol=udp
add action=accept chain=input comment="Allow Everything in Wireguard" \
    in-interface=wireguard1
add action=accept chain=input comment="Allow DNS request for Container - UDP" \
    dst-port=53 in-interface=dockers protocol=udp
add action=accept chain=input comment="Allow DNS request for Container - TCP" \
    dst-port=53 in-interface=dockers protocol=tcp
add action=drop chain=input comment="block everything else"
add action=fasttrack-connection chain=forward comment=\
    "Fasttrack, but not ipsec" connection-mark=!ipsec connection-state=\
    established,related hw-offload=yes
    "Forward established, related, untracked" connection-state=\
add action=drop chain=forward comment="Drop Invalid" connection-state=invalid \
    log=yes log-prefix=invalid
add action=accept chain=forward comment="Forward all outbound traffic" \
    in-interface="Local Bridge" out-interface=Vodafone packet-mark=""
add action=accept chain=forward comment="Allow Wireguard to Subnets" \
    dst-address=10.160.100.0/24 in-interface=wireguard1
add action=accept chain=forward comment="WG to internet" in-interface=\
    wireguard1 out-interface=Vodafone
add action=accept chain=forward comment="Accept dst-nat" \
    connection-nat-state=dstnat
add action=accept chain=forward comment="Forward Docker Traffic to WAN" \
    in-interface=dockers out-interface-list=WAN
add action=accept chain=forward comment="Docker forward rule" in-interface=\
    "Local Bridge" out-interface=dockers
add action=drop chain=forward comment="Drop all Else"
/ip firewall mangle
add action=passthrough chain=prerouting comment=\
    "special dummy rule to show fasttrack counters" disabled=yes
add action=mark-connection chain=prerouting comment="Newgroup Traffic ipsec" \
    connection-state=new dst-port=563 in-interface="Local Bridge" \
    new-connection-mark=ipsec passthrough=yes protocol=tcp
add action=mark-connection chain=prerouting comment=\
    "BitTorrent Ipsec (doesn't filter p2p traffic)" connection-state=new \
    dst-port=16881 in-interface="Local Bridge" new-connection-mark=ipsec \
    "BitTorrent DHT traffic UDP" connection-state=new dst-port=6881 \
    in-interface="Local Bridge" new-connection-mark=ipsec passthrough=yes \
    protocol=udp
add action=masquerade chain=srcnat ipsec-policy=out,none log=yes log-prefix=\
    masq out-interface-list=WAN
add action=dst-nat chain=dstnat comment="Plex TCP" dst-port=32400 \
    in-interface=Vodafone log=yes log-prefix=PlexNAT protocol=tcp \
    to-addresses=10.160.100.30 to-ports=32400
add action=dst-nat chain=dstnat comment=PiHole dst-address=10.160.100.1 \
    dst-port=888 in-interface="Local Bridge" in-interface-list=all protocol=\
    tcp to-addresses=172.17.0.2 to-ports=80
add action=dst-nat chain=dstnat comment=\
    "Force any UDP DNS queries that aren't to pihole to go to pihole" \
    dst-address=!172.17.0.2 dst-port=53 in-interface="Local Bridge" protocol=\
    udp src-address=!172.17.0.2 to-addresses=172.17.0.2
    "Force any TCP DNS queries that aren't to pihole to go to pihole" \
    tcp src-address=!172.17.0.2 to-addresses=172.17.0.2
/ip ipsec identity
add auth-method=eap certificate="" eap-methods=eap-mschapv2 generate-policy=\
    port-strict mode-config=NordVPN peer=NordVPN policy-template-group=\
    NordVPN username=WNGqUUBXZkfY5c3q3SKMYDrY
/ip ipsec policy
add dst-address=0.0.0.0/0 group=NordVPN proposal=NordVPN src-address=\
    0.0.0.0/0 template=yes
/ip service
set telnet disabled=yes
set ftp disabled=yes
set www disabled=yes
set ssh port=2200
set www-ssl certificate=Webfig disabled=no
set api disabled=yes
set winbox address=10.160.100.0/24
/ip smb shares
set [ find default=yes ] directory=/pub disabled=no
add directory=/usb1-part1 name=Container
/ip ssh
set strong-crypto=yes
/ipv6 address
add from-pool=IPv6_Pool interface="Local Bridge"
/ipv6 dhcp-client
add add-default-route=yes interface=Vodafone pool-name=IPv6_Pool prefix-hint=\
    ::/56 request=prefix
/ipv6 firewall address-list
/ipv6 firewall filter
    invalid
    icmpv6
add action=accept chain=input comment="defconf: accept UDP traceroute" \
    dst-port=33434-33534 protocol=udp
    udp src-address=fe80::/10
    protocol=udp
    ipsec-ah
    ipsec-esp
    !listBridge
    icmpv6
    500,4500 protocol=udp
    ipsec-ah
    ipsec-esp
    !listBridge
/ipv6 firewall nat
add action=dst-nat chain=dstnat comment=Pihole dst-address=\
    fe80::4aa9:8aff:fe57:4601/128 dst-port=888 in-interface="Local Bridge" \
    in-interface-list=all protocol=tcp to-address=fe80::c4b1:8cff:fe00:1/128 \
    to-ports=80
add action=dst-nat chain=dstnat comment="Force all UDP DNS queries to pihole" \
    dst-address=!fe80::c4b1:8cff:fe00:2/128 dst-port=53 in-interface=\
    "Local Bridge" protocol=udp src-address=!fe80::c4b1:8cff:fe00:2/128 \
    to-address=fe80::c4b1:8cff:fe00:2/128
add action=dst-nat chain=dstnat comment="Force all TCP DNS queries to pihole" \
    "Local Bridge" protocol=tcp src-address=!fe80::c4b1:8cff:fe00:2/128 \
/ipv6 nd
add interface="Local Bridge" managed-address-configuration=yes
/system clock
set time-zone-name=Europe/London
/system identity
set name=Gateway
/system note
set show-at-login=no
/system ntp client
set enabled=yes
/system ntp server
set enabled=yes manycast=yes multicast=yes use-local-clock=yes
/system ntp client servers
add address=time.cloudflare.com
/tool bandwidth-server
set enabled=no
/tool graphing interface
/tool mac-server
set allowed-interface-list=listBridge
/tool mac-server mac-winbox
/tool romon
set enabled=yes
/tool traffic-monitor
add interface="Port 8 - WAN" name=tmon1
piholeIPv6.rsc (16.3 KB)
Have you tried what I wrote in the other post? http://forum.mikrotik.com/t/pihole-and-ipv6-getting-it-to-work/175706/1
(I haven’t read your current configuration yet).
Just read it and replied to it now with a question. Thank you for your help so far - there’s a bit I don’t get though.
