Struggling with LTE failover (WAP LTE - VLAN passthrough)
i have some issues configuring a LTE failover connection.
My main router is RB4011 with primary ISP on ether1. (Optical provider with PPPoE Client)
I would like to configure my WAP LTE Kit on ether3 as failover connection. (Passthrough mode and DHCP client on RB4011).
WAP LTE:
  • added vlan-mgmt on ether1
  • added vlan-isp on ether 1
  • lte interface APN passthrough interface “vlan-isp”
  • DHCP Client, interface “vlan-mgmt” add default route “yes”
RB4011:
  • added both vlans to ether3
  • added vlan-mgmt to bridge (WAP LTE accessible)
  • added dhcp client “vlan-isp” with default route “yes” and distance=10
Everything works fine. WAP LTE is accessible and when i disconnect my cable on RB4011 ether1 the failover works and LTE is working fine.
BUT my problem is, if i disable default route on my RB4011 dhcp client “vlan-isp” and add a static route with gateway “vlan-isp” it says reachable but i have no internet connection. (I would like to setup netwatch).
With default route “yes” it looks like this:
With default route “no” it looks different (without ip address and internet connection).
