Struggling with traffic flow...
I have a mikrotik with a WAN ethernet link, a LAN ethernet link and a WiFi interface. The LAN/Wifi are bridged and IKEv2 clients come in via the WAN interface.
I have set up traffic flow to be sent to a collector:
/ip traffic-flow> print
                enabled: yes
             interfaces: all
          cache-entries: 256k
    active-flow-timeout: 1m
  inactive-flow-timeout: 15s
This works, but traffic flowing between the bridge interfaces (e.g. WiFI ↔ LAN) is not captured. E.g my query of recorded data from WiFi client shows 0 bytes in lines it should not:
[b]Port	Service		Uploaded	Downloaded	Total[/b]
0	Unknown		45.41 KiB	45.41 KiB	90.82 KiB
53	dns		24.66 KiB	39.34 KiB	64.00 KiB
80	http		354.99 KiB	0.00 Bytes	0.00 Bytes
123	ntp		684.00 Bytes	0.00 Bytes	0.00 Bytes
443	https		640.25 KiB	0.00 Bytes	0.00 Bytes
4500	ipsec-nat-t	32.74 KiB	0.00 Bytes	0.00 Bytes
5223	hpvirtgrp	8.02 KiB	0.00 Bytes	0.00 Bytes
5228	hpvroom		3.51 KiB	0.00 Bytes	0.00 Bytes
The same query when used on a VPN client works fine. E.g:
53	dns	19.49 KiB	39.11 KiB	58.60 KiB
80	http	3.04 KiB	0.00 Bytes	0.00 Bytes
123	ntp	2.08 KiB	0.00 Bytes	0.00 Bytes
443	https	240.22 KiB	180.77 KiB	420.99 KiB
4808	squid	677.77 KiB	1.87 MiB	2.53 MiB
32400	plex	21.25 KiB	63.25 KiB	84.51 KiB
52412	Unknown	0.00 Bytes	9.52 KiB	0.00 Bytes
Is there some limitation that prevents complete capture of netflow traffic flowing between bridged interfaces?
Regards,
Achelon
