stuck at either boot
i have router board 1100 x2
i change the boot setting to either-net
now it’s stuck at either boot ?
i installed new software by net-install but still stuck on either boot
Hi.
Do you think ether-boot ? Do you have any device on your network, which support boot image to your router ?
If not, probably you need to set booting from NAND.
Best regards: CsXen
thank for replay
how to set booting from NAND While the router stuck on either boot ???
