Stuck no internet on CRS326 behind RB4011
Hello, I was hoping I could get some help from the more experienced users here.
I have had an RB4011 for a few years now as a router, currently have some unmanaged switches downstream working fine. Recently acquired a CRS326 and it looks like the RB4011 is just dropping the packets.
I am able to connect via winbox from my desktop hardwired to the RB4011 into the CRS326
ping 8.8.8.8 , ping google.com , and ping my.gateway.ip all timeout on the CRS326 terminal
From the RB4011 side using torch, I see the packets coming in from the CRS326
CRS326 Config:
# jan/04/1970 22:49:00 by RouterOS 6.49.8
# software id = **ELIDED**
# model = CRS326-24G-2S+
# serial number = **ELIDED**
add name=bridge
add name=WAN
add name=LAN
/ip hotspot profile
add bridge=bridge interface=ether1
add bridge=bridge interface=ether2
add bridge=bridge interface=ether3
add bridge=bridge interface=ether4
add bridge=bridge interface=ether5
add bridge=bridge interface=ether6
add bridge=bridge interface=ether7
add bridge=bridge interface=ether8
add bridge=bridge interface=ether9
add bridge=bridge interface=ether10
add bridge=bridge interface=ether11
add bridge=bridge interface=ether12
add bridge=bridge interface=ether13
add bridge=bridge interface=ether14
add bridge=bridge interface=ether15
add bridge=bridge interface=ether16
add bridge=bridge interface=ether17
add bridge=bridge interface=ether18
add bridge=bridge interface=ether19
add bridge=bridge interface=ether20
add bridge=bridge interface=ether21
add bridge=bridge interface=ether22
add bridge=bridge interface=ether23
add bridge=bridge interface=ether24
add bridge=bridge interface=sfp-sfpplus2
add bridge=bridge interface=sfp-sfpplus1
add interface=bridge list=LAN
/ip dhcp-client
add disabled=no interface=bridge
set allow-remote-requests=yes
/system identity
set name="MikroTik CRS326"
/system routerboard settings
set boot-os=router-os
RB4011 config:
# 2024-03-10 05:08:48 by RouterOS 7.12.1
# model = RB4011iGS+
add admin-mac=**ELIDED** auto-mac=no comment=defconf name=bridge
set [ find default-name=sfp-sfpplus1 ] l2mtu=1592
add comment=defconf name=WAN
add comment=defconf name=LAN
/interface lte apn
add name=dhcp ranges=192.168.176.2-192.168.176.200
add address-pool=dhcp interface=bridge lease-time=10m name=defconf
/port
set 0 name=serial0
set 1 name=serial1
/routing bgp template
set default disabled=no output.network=bgp-networks
/routing ospf instance
add disabled=no name=default-v2
/routing ospf area
add disabled=yes instance=default-v2 name=backbone-v2
add bridge=bridge comment=defconf ingress-filtering=no interface=ether2
add bridge=bridge comment=defconf ingress-filtering=no interface=ether3
add bridge=bridge comment=defconf ingress-filtering=no interface=ether4
add bridge=bridge comment=defconf ingress-filtering=no interface=ether5
add bridge=bridge comment=defconf ingress-filtering=no interface=ether6
add bridge=bridge comment=defconf ingress-filtering=no interface=ether7
add bridge=bridge comment=defconf ingress-filtering=no interface=ether8 pvid=8
add bridge=bridge comment=defconf ingress-filtering=no interface=ether9
add bridge=bridge comment=defconf ingress-filtering=no interface=ether10
add bridge=bridge comment=defconf ingress-filtering=no interface=sfp-sfpplus1
set discover-interface-list=none
/ip settings
set max-neighbor-entries=8192
/ipv6 settings
/interface ovpn-server server
set auth=sha1,md5
add address=192.168.176.1/24 comment=defconf interface=ether2 network=\
    192.168.176.0
/ip cloud
set update-time=no
/ip dhcp-client
add comment=defconf interface=ether1 use-peer-dns=no use-peer-ntp=no
add address=192.168.176.0/24 comment=defconf gateway=192.168.176.1 netmask=24
set allow-remote-requests=yes cache-max-ttl=1d max-concurrent-queries=400 \
    max-concurrent-tcp-sessions=400 use-doh-server=https://1.1.1.1/dns-query
/ip firewall address-list
add address=192.168.176.2-192.168.176.254 list=allowed_to_router
add address=0.0.0.0/8 comment=RFC6890 list=not_in_internet
add address=172.16.0.0/12 comment=RFC6890 list=not_in_internet
add address=192.168.0.0/16 comment=RFC6890 list=not_in_internet
add address=10.0.0.0/8 comment=RFC6890 list=not_in_internet
add address=169.254.0.0/16 comment=RFC6890 list=not_in_internet
add address=127.0.0.0/8 comment=RFC6890 list=not_in_internet
add address=224.0.0.0/4 comment=Multicast list=not_in_internet
add address=198.18.0.0/15 comment=RFC6890 list=not_in_internet
add address=192.0.0.0/24 comment=RFC6890 list=not_in_internet
add address=192.0.2.0/24 comment=RFC6890 list=not_in_internet
add address=198.51.100.0/24 comment=RFC6890 list=not_in_internet
add address=203.0.113.0/24 comment=RFC6890 list=not_in_internet
add address=100.64.0.0/10 comment=RFC6890 list=not_in_internet
add address=240.0.0.0/4 comment=RFC6890 list=not_in_internet
add address=192.88.99.0/24 comment="6to4 relay Anycast [RFC 3068]" list=\
    not_in_internet
add address=192.168.0.0/16 list=Bogon
add address=10.0.0.0/8 list=Bogon
add address=172.16.0.0/12 list=Bogon
add address=127.0.0.0/8 list=Bogon
add address=0.0.0.0/8 list=Bogon
add address=169.254.0.0/16 list=Bogon
add action=drop chain=input comment="drop netbios 137" disabled=yes dst-port=137 in-interface-list=LAN protocol=udp
add action=accept chain=input comment="defconf: accept to local loopback (for CAPsMAN)" dst-address=127.0.0.1
add action=drop chain=input comment="defconf: drop all not coming from LAN" in-interface-list=!LAN log-prefix=!frLAN_INPUT
add action=drop chain=input comment="defconf: drop invalid" connection-state=invalid log=yes log-prefix=INVALID_INPUT
add action=drop chain=forward comment="Drop netbios 137" disabled=yes dst-port=137 in-interface-list=LAN protocol=udp
add action=fasttrack-connection chain=forward comment="defconf: fasttrack" connection-state=established,related hw-offload=yes
add action=accept chain=forward comment="Accept incoming natted connections" connection-nat-state=dstnat connection-state=established,related,new,untracked in-interface-list=WAN
add action=drop chain=forward comment="defconf: drop invalid" connection-state=invalid log=yes log-prefix=invalidForward
add action=drop chain=forward comment="Drop tries to reach not public addresses from LAN" dst-address-list=not_in_internet in-interface-list=LAN log=yes log-prefix=!public_from_LAN
add action=drop chain=forward comment="defconf: drop all from WAN not DSTNATed" connection-nat-state=!dstnat connection-state=new in-interface-list=WAN log=yes log-prefix=!NAT
add action=jump chain=forward comment="jump to ICMP filters" jump-target=icmp protocol=icmp
add action=drop chain=forward comment="Drop incoming from internet which is not public IP" in-interface-list=WAN log=yes log-prefix=!public src-address-list=not_in_internet
add action=drop chain=forward comment="Drop packets from LAN that do not have LAN IP" in-interface-list=LAN log=yes log-prefix=LAN_!LAN src-address=!192.168.176.0/24
add action=accept chain=icmp comment="echo reply" icmp-options=0:0 protocol=icmp
add action=accept chain=icmp comment="net unreachable" icmp-options=3:0 protocol=icmp
add action=accept chain=icmp comment="host unreachable" icmp-options=3:1 protocol=icmp
add action=accept chain=icmp comment=\
    "host unreachable fragmentation required" icmp-options=3:4 protocol=icmp
add action=accept chain=icmp comment="allow echo request" icmp-options=8:0 protocol=icmp
add action=accept chain=icmp comment="allow time exceeded" icmp-options=11:0 protocol=icmp
add action=accept chain=icmp comment="allow parameter bad" icmp-options=12:0 protocol=icmp
add action=drop chain=icmp comment="deny all other types"
/ip firewall mangle
add action=log chain=prerouting connection-state=new disabled=yes in-interface-list=WAN
/ip firewall service-port
set ftp disabled=yes
/ip service
set telnet disabled=yes
set www address=192.168.176.0/24,192.168.88.0/24 disabled=yes
set api disabled=yes
set api-ssl disabled=yes
/ip upnp interfaces
add interface=ether1 type=external
/routing bfd configuration
add disabled=no
/system note
set show-at-login=no
/system resource irq rps
set sfp-sfpplus1 disabled=no
You can drop that. Nothing refers to it.
/interface wireless security-profiles set [ find default=yes ] supplicant-identity=MikroTik
You can get rid of that flotsam by upgrading to 7.13+.
/ip dns set allow-remote-requests=yes
You aren’t running a DNS server on the switch. Nuke it.
/interface lte apn set [ find default=yes ] ip-type=ipv4 use-network-apn=no
/routing bgp template set default disabled=no output.network=bgp-networks
/routing ospf instance add disabled=no name=default-v2
/routing ospf area add disabled=yes instance=default-v2 name=backbone-v2
/interface ovpn-server server set auth=sha1,md5
More flotsam, easily removed.
/ip address add address=192.168.176.1/24 comment=defconf interface=ether2 network=192.168.176.0
Here’s your actual problem. Put that on the bridge, not on a single interface.
/ip dhcp-server network add address=192.168.176.0/24 comment=defconf gateway=192.168.176.1 netmask=24
/ip dns set allow-remote-requests=yes cache-max-ttl=1d max-concurrent-queries=400 max-concurrent-tcp-sessions=400 use-doh-server=> https://1.1.1.1/dns-query
If you’re going to provide DHCP and DNS service locally, the DHCP server should advertise your DNS server.
Thank you for your feedback. I implemented your suggestions.
I plugged in a laptop into the CRS 326 and it was able to reach the internet
ping 8.8.8.8
ping 192.168.176.1 (my gateway)
ping google.com
All succeeded and internet is working as expected
However in my winbox session, in the CRS 326 terminal, all those commands are timing out :confused:
I am able to reach other devices in my LAN
[xxxxx@MikroTik CRS326] > ping 192.168.176.1
  SEQ HOST                                     SIZE TTL TIME  STATUS
    0 192.168.176.1                                           timeout
    1 192.168.176.1                                           timeout
    sent=2 received=0 packet-loss=100%
[xxxxx@MikroTik CRS326] > ping 8.8.8.8
    0 8.8.8.8                                                 timeout
    1 8.8.8.8                                                 timeout
[xxxxx@MikroTik CRS326] > ping google.com
invalid value for argument address:
    invalid value of mac-address, mac address required
    invalid value for argument ipv6-address
    while resolving ip-address: could not get answer from dns server
[xxxxx@MikroTik CRS326] > ping 192.168.176.202
    0 192.168.176.202                            56  64 0ms
    1 192.168.176.202                            56  64 0ms
    sent=2 received=2 packet-loss=0% min-rtt=0ms avg-rtt=0ms max-rtt=0ms
It sounds like you’re running on the same stale DHCP config on the switch, from before you fixed things. Presuming you don’t want to wait out the bad DHCP lease, you can restart the switch.
It will work for the same reason your laptop now works.
Thanks for your help!
Restarting the CRS 326 and RB 4011 a few times unfortunately did not resolve the issue. Maybe the bad leases persisted through reboots? I found 2 other LAN clients where the ping timed out from the client to the RB4011 and also timed out in the other direction from the RB4011 to those clients.
What finally fixed the issue for me is:
In the DHCP leases page in Router OS on the RB4011, remove the assigned IP from the clients having issues including the CRS326 and reassign a new IP. After I did that one by one I was able to ping bidirectionally and everything had internet access including the CRS 326 terminal :smiley:
Sure; the RouterOS DHCP server does indeed remember what it assigned previously, so that persistent clients can keep getting the same assignments as long as they keep renewing their leases on time. I just didn’t think it would reapply prior bad configurations, only the parts that remained valid under the new configuration. That’s why I didn’t suggest removing the old leases and forcing them to be regenerated.
Now we both know different. :nerd_face:
Is there a general flush all DHCP leases setting??
/ip/dhcp-server/lease/remove [find where dynamic]
Bewm! Badness-be-gone.
Can I assume this will also work then?
/ip/dhcp-server/lease/remove [find where static]
Sure, it will run, but it destroys the admin’s hand-assigned static reservations. If they’re wrong, they need to be fixed by hand, not destroyed.
That’s why I didn’t write an unqualified “[find]”.
Yes I am the admin and wish to eliminate them LOL…
Update, so it happened again today. But I finally figured it out. The problem is that under IP → ARP, you have to make sure that the MAC is not bound to the old / wrong IP in ARP list.
I was trying to set a static IP to a new machine that was statically set for a different machine previously. I did it in the DHCP leases list. This allowed me to SSH into new machine but new machine could not ping out into the internet. Eventually I stumbled into the ARP list, when I removed the old machine assignment there and added the new one I was able to connect to the internet again.
I guess the ARP list doesn’t refresh often even after restart.
