Stuck on 6.42.1 - cannot upgrade packages - can you help?
Hello everyone.
Could you help me - my core router (RM3011) is stuck on 6.42.1 and I cannot upgrade it to the newest release.
I download/reboot as per normal - the files go into the root folder a-okay. But on reboot the router does not update the firmware.
I have confirmed I have no spare .npk in the root directory. Package list is as follows - note that ipv6 package has been disabled - and I installed it as a separate package during a system test. Is this the issue - I have tried de-activiating and uninstalling the packages but cannot get to work.
[xxxxxxxxxx] /system> package print
Flags: X - disabled
NAME VERSION SCHEDULED
0 X ipv6 6.42.1
1 routeros-arm 6.42.1
2 system 6.42.1
3 X ipv6 6.42.1
4 wireless 6.42.1
5 hotspot 6.42.1
6 dhcp 6.42.1
7 mpls 6.42.1
8 routing 6.42.1
9 ppp 6.42.1
10 security 6.42.1
11 advanced-tools 6.42.1
[xxxxxxx] /system>
Can you help ?
Matt
Did you use the appropriate package ? (ARM)
If you go to System->Packages->Check for updates, what happened?
i have the same Problem. After rebbot all packages are in the file Folder but still the old Firmware.
thanks for your replay.
hello,
i have the same problem. After Upgrade, alle files would be donwloded but after the rebbot nothing happens.
Thanks for your replay.
Thank you for the reply.
Yep, I downloaded the packages direct from the upgrade option on the main menu.
Downloads a-okay and reboots, but does not change the version.
Is something strange going on as I have two copies of ipv6 installed - the combined package, and the separate package?
Can I get back to normal?
Thank you
Matt
Any update?
I have same issue
This was resolved by backing up then Reformatting NAND and flashing latest firmware through net install on a windows machine.
