Stuck on "getting stuff"
I’ve installed a x86 VM on Hyper-V specially to host Dude Server 6.37.3.
After install, configure and put level 4 license, I’ve imported my backup from 4.0beta3.
It imported correctly, including imported my customized images (.svg)
The problem is:
  • I only can log in with an user that has Full permission.
  • Read and Write users get stucked on “getting stuff”
The traffic stays ~1kbps, and the cliente do not log in.
I’ve checked the dude checkbox in the 3 groups.
Any suggestion to this issue?
Is it a known problem that will be fixed in next versions?
:confused:
Try 6.38rc
Also send mail with report to support@mikrotik.com
