Stuck on IF / VLAn / Bridge
Hi all ,
just newbie in MT and have a problem to understand how it works fine…
Coming more from the cisco side so i know trunk, access ports and so on a bit..
so set uo cisco = Router / and Switch with uplinked trunk where all vlans are in ok.
Switch has the access ports and the router should route outside to Internet or if it s needed with ACL one to one other VLAN host.
so what in this scenario is the MT bridge / bridge ports and interface List??
Lets see …
i have one WAN if = eth1
and one uplink which should transport all vlans from the cisco switch e.g. eth5
is that right that i firtst :
create a bridge with pvid1 and ladmin all frame types..
than i add all vlans to the generated bridge ports : eth5 and all vlans exists incl. vlan 1 ?
are they able to communicate in standard to each other via router? If yes -i have to adjust the Firewall?
What is in this case the Interfaces / Interface List ? i have a wan (ether1) and what should be there for LAN ? ( my LAN should be alone also every vlan should only be free to enter the Internet)
all vlans are vlan interfaces with ip on the router and dhcp for the pool
… thanks for a bit explaining.. read some wiki but didnt understand it really…
what is meant with Interfaces list bridges bridge ports..
Regards
c
Hi anav.
thanks first..i read this before..but to be honest…i cant figure out my understanding Problem there :frowning:
https://help.mikrotik.com/docs/display/ROS/Bridge+VLAN+Table (newer)
https://wiki.mikrotik.com/wiki/Manual:Bridge_VLAN_Table (older)
Put your feet in the water and attempt a config.
Hi anav..
that´s what i need :slight_smile: thanks a lot .. i will study it and hope understanding now :slight_smile:
greets
