Hi, I’ve built a basic configuration with VLANs (see simplifyed diagram below
), and while it mostly works, as all VLANs can communicate with the Internet, communicate normally within the VLAN, the inter-vlan routing is just not working (except it works within a switch, but not within the router or between the switch and router). The setup is very simple, practically “by the book”, but it seems I made a mistake somewhere. Could you please help me with that?
Configuration:
Router is RB5009, switch is CRS310, both on the latest stable firmware 7.18.
Notes about configuration:
- IPv6 is disabled for both router and switch for simplicity. So, IPv6 firewall configuration has been removed from the router config output to make it shorter.
- Firewall configuration is default except added a rule for the VLAN routing. Interestingly, this rule never sees virtually any traffic. This is probably a hint, but I didn’t get it so far.
- I have tested all variants for the STP on the bridges (incl. none), but no luck.
Router config:
# ... by RouterOS 7.18
# software id = QHY4-TJ92
# model = RB5009UG+S+
# serial number = HF109XXXXXX
add admin-mac=XX:XX:XX:XX:XX:94 auto-mac=no comment=defconf mvrp=yes name=\
bridge-rb vlan-filtering=yes
/interface vlan
add interface=bridge-rb name=MGMT vlan-id=99
add interface=bridge-rb name=PCs vlan-id=20
add interface=bridge-rb name=Servers vlan-id=10
add comment=defconf name=WAN
add comment=defconf name=LAN
add name=VLAN
/ip hotspot profile
add name=pool-bridge ranges=192.168.5.10-192.168.5.100
add name=pool-management ranges=192.168.99.10-192.168.99.100
add name=pool-PCs ranges=192.168.20.10-192.168.20.100
add name=pool-servers ranges=192.168.10.10-192.168.10.100
add address-pool=pool-bridge interface=bridge-rb name=bridge
add address-pool=pool-management interface=MGMT name=management
add address-pool=pool-servers interface=Servers name=servers
add address-pool=pool-PCs interface=PCs name=pcs
/system ntp key
add key-id=1
/disk settings
set auto-media-interface=bridge-rb auto-media-sharing=yes auto-smb-sharing=\
yes
add bridge=bridge-rb comment="Trunc to switch" interface=ether2
add bridge=bridge-rb comment=defconf frame-types=\
admit-only-untagged-and-priority-tagged interface=ether3 pvid=10
admit-only-untagged-and-priority-tagged interface=ether4 pvid=10
admit-only-untagged-and-priority-tagged interface=ether5 pvid=10
admit-only-untagged-and-priority-tagged interface=ether6 pvid=20
admit-only-untagged-and-priority-tagged interface=ether7 pvid=20
admit-only-untagged-and-priority-tagged interface=ether8 pvid=99
admit-only-untagged-and-priority-tagged interface=sfp-sfpplus1 pvid=10
/interface bridge settings
set use-ip-firewall=yes use-ip-firewall-for-vlan=yes
/ipv6 settings
set disable-ipv6=yes
/interface bridge vlan
add bridge=bridge-rb tagged=bridge-rb,ether2 untagged=ether8 vlan-ids=99
add bridge=bridge-rb tagged=ether2,bridge-rb untagged=\
ether3,ether4,ether5,sfp-sfpplus1 vlan-ids=10
add bridge=bridge-rb tagged=ether2,bridge-rb untagged=ether6,ether7 vlan-ids=\
20
add comment=defconf interface=bridge-rb list=LAN
add interface=MGMT list=LAN
add interface=PCs list=LAN
add interface=Servers list=LAN
add interface=PCs list=VLAN
add interface=Servers list=VLAN
add interface=MGMT list=VLAN
add address=192.168.5.1/24 comment=defconf interface=bridge-rb network=\
192.168.5.0
add address=192.168.99.1/24 comment=management interface=MGMT network=\
192.168.99.0
add address=192.168.20.1/24 comment=pcs interface=PCs network=192.168.20.0
add address=192.168.10.1/24 comment=servers interface=Servers network=\
192.168.10.0
/ip dhcp-client
/ip dhcp-server lease
add address=192.168.5.3 client-id=x:xx:xx:xx:xx:xx:4a comment=CRS310 \
mac-address=XX:XX:XX:XX:XX:4A server=bridge
add address=192.168.10.120 comment="server0" mac-address=\
XX:XX:XX:XX:XX:1F server=servers
add address=192.168.10.110 client-id=x:xx:xx:xx:xx:xx:5b comment=\
"server1" mac-address=XX:XX:XX:XX:XX:5B server=servers
add address=192.168.5.0/24 comment=bridge dns-server=192.168.5.1 gateway=\
192.168.5.1
add address=192.168.10.0/24 comment=servers gateway=192.168.10.1
add address=192.168.20.0/24 comment=pcs gateway=192.168.20.1
add address=192.168.99.0/24 comment=management gateway=192.168.99.1
set allow-remote-requests=yes
/ip dns static
add address=192.168.5.1 comment=defconf name=router.lan type=A
established,related,untracked
invalid
in-interface-list=!LAN
ipsec-policy=in,ipsec
ipsec-policy=out,ipsec
add action=accept chain=forward connection-state=new in-interface-list=VLAN \
out-interface-list=VLAN
connection-state=invalid
/ip firewall service-port
set h323 disabled=yes
set sip disabled=yes
/system clock
set time-zone-name=XXXXXXXXXX
/system identity
set name=RB5009
/system note
set show-at-login=no
/system ntp client
set enabled=yes
/system ntp server
set auth-key=1 broadcast=yes enabled=yes manycast=yes multicast=yes
/system ntp client servers
add address=pool.ntp.org
/tool mac-server
/tool mac-server mac-winbox
Switch config
# software id = Z8R7-YY9K
# model = CRS310-8G+2S+
# serial number = HG909XXXXXX
add admin-mac=XX:XX:XX:XX:XX:4A auto-mac=no comment=defconf mvrp=yes name=\
bridge-crs vlan-filtering=yes
/interface vlan
add interface=bridge-crs name=MGMT vlan-id=99
add interface=bridge-crs name=PCs vlan-id=20
add interface=bridge-crs name=Servers vlan-id=10
/ip hotspot profile
/system ntp key
add key-id=1
add bridge=bridge-crs comment="Trunc to router" interface=ether1
add bridge=bridge-crs comment=defconf frame-types=\
admit-only-untagged-and-priority-tagged interface=ether2 pvid=20
admit-only-untagged-and-priority-tagged interface=ether3 pvid=20
admit-only-untagged-and-priority-tagged interface=ether4 pvid=20
admit-only-untagged-and-priority-tagged interface=ether5 pvid=20
admit-only-untagged-and-priority-tagged interface=ether7 pvid=10
admit-only-untagged-and-priority-tagged interface=sfp-sfpplus2 pvid=10
/ipv6 settings
add bridge=bridge-crs tagged=ether1 untagged=ether8 vlan-ids=99
add bridge=bridge-crs tagged=ether1 untagged=\
ether2,ether3,ether4,ether5,ether6 vlan-ids=20
add bridge=bridge-crs tagged=ether1 untagged=ether7,sfp-sfpplus1,sfp-sfpplus2 \
vlan-ids=10
add address=192.168.5.3/24 comment=defconf interface=bridge-crs network=\
192.168.5.0
add address=192.168.99.3/24 interface=MGMT network=192.168.99.0
add address=192.168.10.3/24 interface=Servers network=192.168.10.0
add address=192.168.20.3/24 interface=PCs network=192.168.20.0
/system clock
/system identity
set name=CRS310
/system note
/system ntp client
set enabled=yes
add address=192.168.5.1 auth-key=1
Thank you.
