Stuck with my Wireguard config
I am trying to setup a wireguard connection between my router and a laptop (“roadwarrior” style). I am unable to get an handshake. I triple checked my keys, but I am still stuck. I don’t know what to check/test to locate and solve the issue. I post my config bellow. Any help appreciated.
Thanks in advance !
# 2025-02-11 12:31:59 by RouterOS 7.17.2
# model = RB5009UPr+S+
add admin-mac=XXX auto-mac=no comment=defconf name=bridge \
    port-cost-mode=short
set [ find default-name=ether2 ] l2mtu=1500 poe-out=off
/interface wireguard
add comment="Roadwarrior VPN to LAN" listen-port=13231 mtu=1420 name=\
    wireguard1
add name=WAN
add name=LAN
add name=default-dhcp ranges=10.9.9.100-10.9.9.254
add address-pool=default-dhcp interface=bridge lease-time=1d name=lan_dhcp
add bridge=bridge interface=ether1 internal-path-cost=10 path-cost=10
add bridge=bridge interface=ether2 internal-path-cost=10 path-cost=10
add bridge=bridge interface=ether3 internal-path-cost=10 path-cost=10
add bridge=bridge interface=ether4 internal-path-cost=10 path-cost=10
add bridge=bridge interface=ether5 internal-path-cost=10 path-cost=10
add bridge=bridge interface=ether6 internal-path-cost=10 path-cost=10
add bridge=bridge interface=ether7 internal-path-cost=10 path-cost=10
add bridge=bridge interface=ether8 internal-path-cost=10 path-cost=10
set udp-timeout=10s
add interface=bridge list=LAN
add interface=sfp-sfpplus1 list=WAN
/interface ovpn-server server
add mac-address=... name=ovpn-server1
/interface wireguard peers
add allowed-address=10.9.8.226/32 comment="My laptop" interface=\
    wireguard1 name=AAA public-key=\
    "XXX"
add address=10.9.8.1/22 interface=bridge network=10.9.8.0
add address=10.9.8.225/27 comment=VPN interface=wireguard1 network=10.9.8.224
/ip dhcp-client
add address=10.9.8.0/22 dns-server=10.9.8.1 gateway=10.9.8.1
set allow-remote-requests=yes cache-size=20480KiB
/ip dns adlist
add ssl-verify=no url=\
    https://raw.githubusercontent.com/StevenBlack/hosts/master/hosts
    established,related,untracked
    invalid
add action=accept chain=input comment="Accept incoming wireguard" dst-port=\
    13231 packet-mark="" protocol=udp
    in-interface-list=!LAN
    ipsec-policy=in,ipsec
    ipsec-policy=out,ipsec
    connection-state=invalid
add action=dst-nat chain=dstnat comment=VOIP dst-port=5060 in-interface-list=\
    WAN protocol=tcp to-addresses=10.9.11.3 to-ports=5060
/ip hotspot profile
/ip ipsec profile
/ip smb shares
set [ find default=yes ] directory=pub
/ipv6 address
add address=::1 from-pool=general-pool6 interface=bridge
/ipv6 dhcp-client
add add-default-route=yes interface=sfp-sfpplus1 pool-name=general-pool6 \
    request=prefix use-peer-dns=no
/ipv6 firewall address-list
/ipv6 firewall filter
    invalid
    icmpv6
add action=accept chain=input comment="defconf: accept UDP traceroute" port=\
    33434-33534 protocol=udp
    udp src-address=fe80::/10
    protocol=udp
    ipsec-ah
    ipsec-esp
    !LAN
    icmpv6
    500,4500 protocol=udp
    ipsec-ah
    ipsec-esp
    !LAN
/ipv6 nd
set [ find default=yes ] interface=bridge ra-interval=20s-1m
/tool mac-server
/tool mac-server mac-winbox
Why do you have specific mention of packet-mark in that accept rule for wireguard port ?
Make it blank and unselected.
Secondly, it might be better to use separate IP subnet for wireguard connections. You currently have overlap with your LAN.
When you split it out, be careful accepting Wireguard interface itself for communication too (or add wireguard interface to LAN list).
Thanks for you quick answer. I removed the spurious ‘packet-mark’ setting in the FW rules without success. I also tried to split the network. Here is my new config. Still no handshake. Are there other things I could check ?
# 2025-02-11 14:40:57 by RouterOS 7.17.2
    wireguard1
add name=WAN
add name=LAN
set udp-timeout=10s
add interface=wireguard1 list=LAN
add mac-address=FE:78:80:A8:78:03 name=ovpn-server1
add allowed-address=10.10.10.2/32 comment="laptop" interface=\
    wireguard1 name=AAA public-key=XXX
add address=10.10.10.1/24 comment=VPN interface=wireguard1 network=10.10.10.0
/ip dhcp-client
/ip dns adlist
    invalid
    13231 protocol=udp
    "Accept all wireguard incoming traffic" disabled=yes in-interface=\
    wireguard1 src-address=10.9.8.224/27
/ip hotspot profile
/ip ipsec profile
/ip smb shares
/ipv6 address
/ipv6 dhcp-client
    invalid
    icmpv6
    protocol=udp
    ipsec-ah
    ipsec-esp
    !LAN
    icmpv6
    ipsec-ah
    ipsec-esp
    !LAN
/ipv6 nd
/tool mac-server
In case the problem is elsewhere, I also attach the client config:
[Interface]
Address = 10.10.10.2/32
PrivateKey = AAA
Dns = 10.9.8.1
[Peer]
PublicKey = BBB
AllowedIPs = 0.0.0.0/0
Endpoint = xxx.xxx.xxx.xxx:13231
Is that RB5009 your direct connection to internet ?
Or is there an ISP router in between ?
If there is, is on the router the needed port forwarded to your RB5009 ?
The first thing you should see, is in firewall increase for the counter for that accept rule for port 13231.
As long as that is not moving, nothing is reaching your router.
As already stated: You do not have an accept rule for the incoming wireguard handshake.
add chain=input action=accept comment=“wg handshake” dst-port=13231 protocol=udp
I would also be clearer on forward chain.
Change default rule
“defconf: drop all from WAN not DSTNATed” connection-nat-state=!dstnat
TO:
add action=accept chain=forward comment=“internet traffic” in-interface-list=LAN out-interface-list=WAN
add action=accept chain=forward comment=“wg to LAN” in-interface=wireguard1 dst-address=10.9.8.0/24
add action=accept chain=forward comment=“port forwarding” connection-nat-state=dstnat
add action=drop chain=forward comment=“drop all else”
Edit: I was looking at the wrong config, I see you have the above fixed ( input chain rule ). Confirm you get a public IP!!!
Directly connected to the internet. The WAN IP adress is public and can be pinged from the outside.
If I try to send a dummy packet to port 1321 using the WAN adress it does not work, and the counter does not increase:
echo "hello" | nc -u XXXX 13231
SOLVED: It was a stupid dynamic DNS update problem. The endpoint did change between two tests. Now everything works well with the configuration posted above. Many thanks.
Awesome glad its working for you.
Yea. As often the problem is not where I am focusing…
