Stuck with RB750 Switching VLANs!
Do you have fasttrack enabled in firewall? It should be enabled by default.
Which routerOS do you use?
:face_with_peeking_eye: hehehe, I didn't think to reboot the router earlier,
there is no firewall that I use on the router under the modem
rOS6 stable latest
My last configuration cut off access to the router under the modem.
I'm trying to find a way to telnet the router via Mac telnet, but it doesn't work.
Strangely, the ARP on the Mac modem is detected and shows DC status, but it doesn't replay.
Once you enabled switch1-cpu you activated VLAN filtering..
If you are lucky you can access your router via ports which have vlan-mode=disabled..
Else only reset to defaults… and start over..
strange but true, after I rebooted and upgraded Ros, the switch configuration worked
:rofl:
