Hi there, I’m studying some networking and Mikrotik routeros. I’m a newbie, so please don’t blame me.
Just as a try, I set a RB760 as a main router and a hAP ac lite as a switch with access point. I know it’s not the best config, but I just wanted to learn a little about VLANs.
Now, port 5 of RB60 is carrying VLAN ids 20 and 30 (my trunk port). In hAP ac lite I have the trunk port and one port dedicated to each of the VLANs by using the switch chip.
If I connect a PC to either port 3 or 4 of the “hAP switch”, PC gets correctly the Vlan IP, I can ping everything but if I open up the web browser, all the google services are very well reachable and reactive but I can’t browse other websites or the connection works just from time to time. The connection icon in Windows says “internet present”. Could you help me in understanding what’s wrong in this first setup?
Thanks and regards
Here’s the configuration of the RB760 (rOS 6.49.2)
add dhcp-snooping=yes igmp-snooping=yes name=bridge234
set [ find default-name=ether1 ] comment=WAN-DCHP_client name=ether1-WAN
set [ find default-name=ether2 ] name=ether2-br
set [ find default-name=ether3 ] name=ether3-br
set [ find default-name=ether4 ] name=ether4-br
set [ find default-name=ether5 ] name=ether5_VLAN_Trunk
/interface vlan
add interface=ether5_VLAN_Trunk name=vlan20 vlan-id=20
add interface=ether5_VLAN_Trunk name=vlan30 vlan-id=30
add include=static name=BridgeIntList
/ip hotspot profile
add name=bridgePool ranges=10.1.1.241-10.1.1.253
add name=dhcp_pool1 ranges=10.20.20.241-10.20.20.253
add name=dhcp_pool2 ranges=10.30.30.241-10.30.30.253
add address-pool=bridgePool disabled=no interface=bridge234 lease-time=1d name=\
dhcp_s_bridge
add address-pool=dhcp_pool1 disabled=no interface=vlan20 lease-time=1d name=\
dhcp1
add address-pool=dhcp_pool2 disabled=no interface=vlan30 lease-time=1d name=\
dhcp2
add bridge=bridge234 interface=ether2-br
add bridge=bridge234 interface=ether3-br
add bridge=bridge234 interface=ether4-br
add interface=ether2-br list=BridgeIntList
add interface=ether3-br list=BridgeIntList
add interface=ether4-br list=BridgeIntList
add address=10.1.1.254/28 interface=bridge234 network=10.1.1.240
add address=10.20.20.254/28 interface=vlan20 network=10.20.20.240
add address=10.30.30.254/28 interface=vlan30 network=10.30.30.240
/ip dhcp-client
add disabled=no interface=ether1-WAN
add address=10.1.1.240/28 dns-server=8.8.8.8 gateway=10.1.1.254
add address=10.20.20.240/28 dns-server=192.168.1.220,8.8.8.8 gateway=\
10.20.20.254
add address=10.30.30.240/28 dns-server=192.168.1.220,8.8.8.8 gateway=\
10.30.30.254
add action=masquerade chain=srcnat to-addresses=192.168.1.149
/system clock
set time-zone-name=Europe/Rome
/system identity
set name=hEX-BLACK
Here’s the configuration of hAP
# jan/02/1970 00:46:13 by RouterOS 6.49.7
# software id = GR8W-HM0T
# model = RB941-2nD
# serial number = D0550D2B15C1
add dhcp-snooping=yes igmp-snooping=yes name=bridgeVLAN
/interface wireless
set [ find default-name=wlan1 ] ssid=MikroTik
set [ find default-name=ether1 ] comment="Winbox Safe"
set [ find default-name=ether2 ] name=ether2-Trunk
set [ find default-name=ether3 ] name=ether3VLAN20
set [ find default-name=ether4 ] name=ether4VLAN30
set 1 vlan-header=add-if-missing vlan-mode=secure
set 2 default-vlan-id=20 vlan-header=always-strip vlan-mode=secure
set 3 default-vlan-id=30 vlan-header=always-strip vlan-mode=secure
add include=static name=Winbox
add bridge=bridgeVLAN interface=ether2-Trunk
add bridge=bridgeVLAN interface=ether3VLAN20
add bridge=bridgeVLAN interface=ether4VLAN30
add bridge=bridgeVLAN interface=wlan1
add ports=ether2-Trunk,ether3VLAN20 switch=switch1 vlan-id=20
add ports=ether2-Trunk,ether4VLAN30 switch=switch1 vlan-id=30
add interface=ether1 list=Winbox
/system identity
set name=hAP-WHITE
