Yes, I have still problem.
I cannot reach the webserver, I see in the connection tracking of the firewall, the syn packet of tcp, but I don’t see any reply. (In the lan I reach the webserver).
If I torch the ether1, I see the connection form my host to the webserver. No idea because the rule don’t work.
How can i see the firewall log of mikrotik?
Many thanks.
Did you cleared connection table after setting nat rule? If you had connection tracking entry already in the table before nat rule was added then, it will not work until connection table is cleared.
Look if nat rule is matching any packets
/ip firewall nat print stats
