This means if I have 200 users I will have 200 rules on simple queue. Now since Mikrotik has more than what I knw. Please give me alternative way to put just one rule that will serve the whole subnet 172.168.0.0/24 and give the same effect in terms of limiting and bursting as the above sample rule. I have heard of PCQ but have never been able to make it work on my application.
Thanks but bursting is the main issue. Otherwise the simple queue for each user ip works ok with burst. I only need a simple rule that will apply for the whole subnet.
I have added the max-limit but still the same problem. I have a feeling that there is some rules in hotspot setup and NAT which are preventing the mangle rule for pcq. Please assist if u have any idea.
Use PCQ which I’ve did to my clients. Don’t use MAX-Limit, because it will apply to whole flow instead of per client wise. Also, bursting won’t be supported as far as I concerned.
