Subnet to ports
Hi everyone!
I’m new to Mikrotik routers, so my apologies for my simple or weir question. :slight_smile:
At this moment we use an old Juniper router to route a public /29 subnet to different ports.
I don’t know what is the best/easiest way to configure this in Mikrotik.
Current setup;
ETH0; interface to our ISP;
Address 1.1.1.82/30
Interface with static route to ISP:
route 0.0.0.0/0 next-hop 1.1.1.81
All other interfaces (except ETH1 for management purposes);
address 2.2.2.185/29
On this interfaces, other users can connect their own router. For example with the following settings;
IP 2.2.2.188
Netmask 255.255.255.248
Gateway 2.2.2.185
*IP addresses (except last octet) randomized for privacy reasons.
Question;
How can i make sure i an use address 2.2.2.185/29 on all interfaces?
Thanks for helping me out!
It sounds like you want bridge containing all those interfaces and 2.2.2.185/29 on this bridge.
From blank..
Create a bridge with all the ports except the one you are connecting to your ISP..
IP - Addresses
Add 2.2.2.185/29 to the bridge interface.
Assign 1.1.1.82/30 to the interface connected to your ISP.
IP - Route
0.0.0.0/0 gateway 1.1.1.81
Add firewall rules as desired, but the above will do what you are asking.
