Currently my RB951G has on ether1 connection to isp, ether5 lan 192.168.1.x, and tried to add on ether3 separate lan 192.168.4.x without access to 192.168.1.x. Have one device connected to ether3 but keep getting 192.168.1.x
[admin@MikroTik] > /interface vlan print
NAME MTU ARP VLAN-ID INTERFACE
0 R vlan2-guest 1500 enabled 2 ether3
/interface vlan print detail
0 R name="vlan2-guest" mtu=1500 l2mtu=1594 mac-address=4C:5E:0C:34:E7:96 arp=enabled arp-timeout=auto loop-protect=default loop-protect-status=off loop-protect-send-interval=5s loop-protect-disable-time=5m vlan-id=2 interface=ether3
use-service-tag=no
/ip dhcp-server print detail
Flags: D - dynamic, X - disabled, I - invalid
0 name="defconf" interface=bridge lease-time=10m address-pool=dhcp bootp-support=static authoritative=yes use-radius=no lease-script=""
1 name="dhcp-guest" interface=vlan2-guest lease-time=10m address-pool=dhcp-guest-pool bootp-support=static authoritative=yes use-radius=no lease-script=""
/ip address print detail where interface=vlan2-guest
0 address=192.168.4.1/24 network=192.168.4.0 interface=vlan2-guest actual-interface=vlan2-guest
