Subnetting Isse
Hi Guys… :slight_smile:
i’m using RouterOS 6.4 on X86
my datacenter is telling me to use 255.255.255.255 as subnet mask and in mikrotik it means IP address with /32 (if i’m not mistaking) but when i set the IP address with /32 Subnet then the router cant ping the gateway and it says “no route to host”
as far as i know the gateway must be on the same net mask as the IP address of the router, and the error is wright
then i tried the IP address with /8 Subnet, walla ! it worked… but after 2-3 days my ip was Blocked from the datacenter
when i asked them for the reason, they told me i had a lot of IP failover traffic … !
any solutions ? :confused:
