Substring from Variable
I have a variable that stores an IP with a subnet:
:local IPADDR "192.168.1.1/24"
If I want another variable set to just the first part of that (just the IP, without the “/24”), is there a way to do this?
Related, but sort of separate question:
I noticed that MikroTik supports regex - is there a way to maybe use regex to specify which part of the first variable I want to assign to the second variable? Kind of like “[0-9].[0-9].[0-9].[0-9]” - that sort of thing? Or is regex only used on MikroTik to do layer 7 domain matching?
:local IPADDR “192.168.1.1/24”
:local TEST [:pick $IPADDR 0 [:find $IPADDR “/”]];
:put $TEST
Awesome! Thanks!
