Success Story OSPF/BGP
after a long time of hassling with OSPF/BGP on ROS it is real stable
now.
RB1000/ROS3.30/Routing test:
Uptime: 246d
Peers up: 46d
Full BGP Internet Feed
iBGP
OSPF
No problems, just running
:slight_smile:)
How many peers do you have?
Looks very impressive
3x RB1000 each has one external full feed.
Interconnected with iBGP.
Nice…could you explain your setup? very interested to know why you have 3x Feeds? Do you route different public IP’s to different ISP’s?
I’ve an own netblock/AS announcing it with BGP. 2x100 to one Uplink-Carrier and 1x to a second.
It’s for redundancy.
2 Full feed EBGP + 1 IBGP
99d uptime
99d peer uptime
What version are you running Medianet?
/system resource> pr
                   uptime: 14w2d15h16m27s
                  version: "4.5"
              free-memory: 1452020kB
             total-memory: 1946124kB
                      cpu: "Intel(R)"
                cpu-count: 1
            cpu-frequency: 3000MHz
                 cpu-load: 21
           free-hdd-space: 92930kB
          total-hdd-space: 122703kB
  write-sect-since-reboot: 15830
         write-sect-total: 52774648
        architecture-name: "x86"
               board-name: "x86"
> /system resource pri
                   uptime: 23w3d11h29m1s
                  version: "4.3"
              free-memory: 876300kB
             total-memory: 1556056kB
                      cpu: "e500v2"
                cpu-count: 1
            cpu-frequency: 1333MHz
                 cpu-load: 19
           free-hdd-space: 484700kB
          total-hdd-space: 520192kB
  write-sect-since-reboot: 3625119
         write-sect-total: 4731573
               bad-blocks: 6
        architecture-name: "powerpc"
               board-name: "RB1000"
Handles a full feed directly, plus one via iBGP, both IPv4 and IPv6.
Doing any padding or anything of the like?
Padding? We do a bit of traffic engineering, such as setting communities and changing local-pref.
